    PI3+ and gamecube Emulator
    gamecubepi3+
    29 Posts 13 Posters 50.1k Views
    • KN4THXK
      KN4THX
      What are the incremental advancements in GPU since the Pi 1? Has it been mostly just CPU jumps?
      "If you're gonna play the Game Boy, You gotta learn to play it right" - https://www.youtube.com/watch?v=FYLGl92ETNQ
        barbudreadmon @KN4THX
        @thedatacereal i think the gpu is actually the only thing that never changed since the first rpi
          mike831
          Isn't the retropie more powerful than the gamecube? At least on paper. Why can't it handle gamecube or supersmashbros? Please don't just comment and say "it works on mine" that's great, but unfortunately it doesn't work on everyones, so if you're not here to help please don't comment.
          BuZzB 1 Reply Last reply Reply Quote -3
            BuZz administrators @mike831
            @mike831 because you have to emulate all the systems hardware and complicated timings. Google a bit about how emulation works.
            Eg. Considering the SNES - https://www.tested.com/tech/gaming/2712-why-perfect-hardware-snes-emulation-requires-a-3ghz-cpu/
            (Can have higher level emulation - which works bit differently - for some systems, and that's the only reason some N64 games are playable on the RPI. Wii is beyond the capabilities).
            Did you read the whole thread? I'm sure I'm just repeating stuff that has been said here before.
              tywood
              You maaaaaaaayyyybbbeeeeee with the libre computer board at a higher clock speed run game cube games. But it's double the price and doesn't really have much software support... but maybe here's the link if you want to look into it: https://www.amazon.com/Libre-Computer-AML-S905X-CC-Potato-64-bit/dp/B074P6BNGZ/ref=cm_cr_arp_d_product_top?ie=UTF8
                tywood
                sorry wrong link just look for the 4gb of ram model
                  tywood @drake999
                  @drake999 dooooitttttt pllzzzzz XD
                  • EcksE
                    Ecks @barbudreadmon
                    @barbudreadmon said in PI3+ and gamecube Emulator:
                    @ecks said in PI3+ and gamecube Emulator:
                    Have to agree with him on that one and the only way we could see more emulation like Gamecube, PS2 and high graphic mame games that uses CHD files is if they come out with a Pi 4 that i would assume need to be like 1.8GHz and double the GPU power.
                    Edit: Oh and would have at least 4GB DDR2 memory.
                    Lol. I have a 2.56Ghz cpu with 8Gb ram, it won't run those, it won't run Sega Saturn either, it won't even run the "performance" version of bsnes. If you want to see those systems on rpiX, wait for a 3Ghz cpu, or find a good c/c++ developper willing to write dynarecs for those emulators.
                    I know i am a little late on this but having a PC that has 2.56GHz and 8GB of memory you need a good GPU as well because i have an old system which is using a Athlon 5350 with 8gb memory and a HD 7750 and i am able to emulate Gamecube and PS2 games perfectly fine and also the Athlon 5350 is clocked in at 2.05GHz quad core which is why i believe if they would make a Pi 4 it should be able to handle 2.5D PS2/Gamecube games and higher graphic mame games without any problems.
                      barbudreadmon @Ecks
                      @Ecks said in PI3+ and gamecube Emulator:
                      I'll admit cpu frequency is not the most accurate indicator, you would need more proper benchmark, however :
                      • it seems your Athlon 5350 @2.05 Ghz actually has better single thread performance than my pentium N3710 @2.56Ghz
                      • at the same cpu frequency, i expect an arm cpu to be slower than a x86 cpu (i always heard the old rpi1@700Mhz was roughly equivalent to an old pentium2@400Mhz in terms of single thread performance)
                      • your expectations are way too high about the gpu for the next raspberry, even if the future VC5 was any good, i doubt it would outperform the desktop class gpu included in my pentium N3710
