    Cap, mame roms not running
    roms cps mame
    5 Posts 3 Posters 1.8k Views
      Jonboy10071979
      I've started making me a game system with retro pie 3 . I'm at a standstill . Some mame roms and cps roms are not playing . Do they need bios or something else. I have a good bit that are working . Golden axe , cruisn usa and alot of the xmen or marvel do not run can someone help!
        MAME is a bit more involved when finding the right ROMs, start from https://retropie.org.uk/docs/Arcade/ and then consider which ROM set you'll need in order to make it work with the MAME emulator you're using.
        Also, please don't post a support question without https://retropie.org.uk/forum/topic/3/read-this-first - knowing which emulator/system are you using makes things much more easier to understand.
          Jonboy10071979 @mitu
          @mitu ok yes I read that before I posted . I see alot of people talking about rom sets and get the right one. How do I know it's the right one? I use fba on retropie 3 b+
            mitu Global Moderator @Jonboy10071979
            @jonboy10071979 As pointed on the page I referenced, the lr-fbalpha included in the latest version of Retropie uses the FB Alpha v0.2.97.42 Rom version.
            • W
              ward614
              On finding the right romset: The easiest way of doing this is to make sure that the one you download is labeled with which set it is from. This will make most games (60%-70%) work right out of the box if you select an emulator designed to work with that romset (see Here and Here). The remainder can usually be made to work by trying different emulators or seeking out another rom.
              Basically, it is prohibitively difficult to find out which romset you have if it isn't labeled from the get go. Much easier to look for one that is marked.
              If the screen goes black after a game is selected and then returns to the main menu, your emulator and rom are not compatible and you should change one of those two things.
