Scraped images showing up for nes, megadrive and n64 but not snes
  • I found a really cool scraper called Universal XML scraper which puts a game image and the box art together into a .png file. I have been able to add the images to my nes, megadrive and n64 emulators, but after adding them for my snes emulator they don't seem to show up regardless of which UI I choose. It's always just a black frame.
    Pi Model or other hardware: Raspberry Pi 3 Model B
    Power Supply used: Model DSM-0525 input AC100-240V-50/60Hz | Output: 5V 2.5A
    RetroPie Version Used : 4.3.16 (d3e4361)
    Built From: retropie-4.3-rpi2_rpi3.img
    USB Devices connected: SNES style gamepad
    Controller used: SNES style gamepad
    Error messages received: no error
    Log found in /dev/shm/runcommand.log (if relevant): log not found
    Guide used: EmulationStation scraper guide on this site and Universal XML Scraper on github. The guide for this is
    File: retropie/configs/all/.emulationstation/gamelists/snes/gamelist.xml
    Emulator: lr-snes9x2002 and lr-snes9x2005
    Attachment of config files:
    /retropie/configs/all/.emulationstation/es_systems.cfg
    https://pastebin.com/0tFaNxJe
    /retropie/configs/all/.emulationstation/gamelists/snes/gamelist.xml (shortened to just the first entry for brevity)
    https://pastebin.com/EHEyPBPS
    How to replicate the problem: Boot Pi and choose SNES emulator from EmulationStation. Games will have black frame instead of the images located in /retropie/configs/all/.emulationstation/downloaded_images/snes/
  • Global Moderator
    @vaylen Your problem is something in your particular configuration/scraped info. Post the complete gamelist.xml for the SNES system and check that the images are actually downloaded and correct.
  • So EasyHax pointed out to me that any gamelist.xml file in the roms directory will override the one in the .emulationstation/gamelists/ directories. Sure enough I found a 0 byte gamelist.xml file in the snes roms directory. It HAD to be something this simple...
