    Hotkey help
    hotkey
    5 Posts 2 Posters 550 Views
      gizmobjb
      Some how I changed the hotkey so when it is pressed it opens the retroarch menu and I cant get it back to hotkey+x. This is causing me no to be able to use any hotkey
      Please help
        ChuckyP
        You can press start form the emulationstation menu and reconfigure your input. The last button option is the hot key and you can set it from there.
          gizmobjb
          I did that but in game the hotkey opens the retroarch menu I use to have to push the hotkey+x. I cant figure out how to change it back.
            ChuckyP
            Interesting. I just pulled up the menu to see what could have been changed. But I can’t think of what could have caused that.
            It should be a hotkey+”button” to enter the menu. I can’t think of a way to open the menu by just pressing Select, even if I wanted too.
            I’m sure someone will have an idea what to look for.
              gizmobjb
              So my son just admitted he was messing around and went in to the online updater in retroarch and updated the controller. I am not home so sorry if the descriptions are off. Not sure if that's what did it or not
