    Need help with NES video settings
    nesrgbcolorhelpgraphics
    6 Posts 2 Posters 1.6k Views
    • SonPluckS
      SonPluck
      Setup:
      • Raspberry Pi 3
      • Samsung EVO 32GB Micro SD Card
      • Retropie v4.3
      Okay this might be a pretty dumb question, but how can I turn my games from this:
      To this RGB mod like look:
      Any suggestions on how I can change my NES colors to a more natural look?
        mediamogul Global Moderator @SonPluck
        @sonpluck
        You can set the color palette in the core settings of lr-fceumm and lr-nestopia. It's generally agreed upon that 'sony-cxa2025as-us' is closest to original NTSC hardware, but I'm not sure about PAL.
        • SonPluckS
          SonPluck
          Thanks for the quick reply! btw are these only color settings I can change?
          Also, how can I save the core settings for a specific ROM?
            @sonpluck said in Need help with NES video settings:
            I believe so, yes.
            They should save automatically once set.
            • SonPluckS
              SonPluck
              Alright cool, thanks for the help!
                @sonpluck
                Not a problem.
