Scummvm mouse control issue.
Hi again,
Since upgrading to stretch and a 3b+ when I go into scummvm there is a small black cursor that never moves to the left, and my main cursor is limited in its motion. I also noticed this in dosbox when key mapping. I believe somehow mouse movement is set to analog stick, but that does not move the cursor at all.
The reason I believe its mapped like a stick is because it only seems to have a circular range of motion in dosbox, and scummvm just is messed up movement in general, the cursor feels like it is on a rubber band.
Any ideas?
Dosbox definitely has a rotation, I can move with the mouse but only within a circle that snaps back to center that's def analog stick mapping. Where do I change that setting I have not come across any for mouse.
