    2.4GHz usb adapter to SF30 and SN30 controllers with 2.4GHz 8bitdo receiver?
    8bitdosnes2.4ghz
    3 Posts 3 Posters 3.1k Views
      Panamanian
      Hi guys, I recenly (by mistake), bought a 8bitdo, SNES controller (wireless 2.4ghz) but with a 2.4Ghz receiver which I recenly noticed that the connector is something like "SN30 or SFC3.0), I thought initially that it was a usb port.
      My question is, does raspberry or retropie recognize 2.4ghz devices (that require a dongle)?
      If not..., can I buy a 2.4ghz usb adapter to replace the one the controller came with?
      This is the controller I bought in amazon. alt text
      Link: link text
      This is the adapter it came: alt text
      The adapter i 'm refering (in case it would work with this) is similar to this (the one at the right, USB ADAPTER for PC, Android):
      Also, just in case what should I see? frequency?
      Thanks a lot in advance.
      mituM RionR 2 Replies Last reply Reply Quote 0
        mitu Global Moderator @Panamanian
        @panamanian AFAIK this kind of wireless adapters are not something standard, but vendor specific - you'll not be able to use them inter-changeably. If you want to keep the controller, better get a SNES<->USB converter, otherwise return it and get a similar Bluetooth controller.
        • RionR
          Rion @Panamanian
          @panamanian I think you need to get the 8Bitdo Wireless USB Adapter
          Please someone correct me if I'm wrong?
          Edit: No. I was wrong.
          Controller Compatibility
          8Bitdo controllers and arcade sticks (excluding 2.4G controllers)
          That's to bad. Wish they would release a USB Adapter for the 2.4ghz models.
          FBNeo rom filtering
          Mame2003 Arcade Bezels
          Fba Arcade Bezels
          Fba NeoGeo Bezels
