    Multi Switch Shutdown Script!
    shutdown scriptshutdown switchcyperghost
    272 Posts 40 Posters 132.9k Views
      cyperghost @Idelacio
      @idelacio you should tag people to get response. Nevertheless it's easy to fix. I have written a solution here. https://github.com/RetroFlag/retroflag-picase/issues/90#issuecomment-676587374
      jamrom2J IdelacioI 2 Replies Last reply Reply Quote 1
      • jamrom2J
        jamrom2 @cyperghost
        @cyperghost Hello. I have a question on a Mausberry shutdown script I'm hoping to get advice on before I go down the Support road from the manufacturer. I hear the support is not that good, so I'm throwing my last dart.
        I converted an Intellivision Flashback unit into a Retropie, using a Mausberry for the shutdown. This is my 2nd unit I've built with no issues. The newest image of Retropie, whatever O/S it's built on, doesn't seem to like the Mausberry script and leaves the shutdown sequence hanging, never powering off.
        I tested the Mausberry with and older SD card I had with the previous Retropie build (4.6.7)... works like a charm. The new Retropie image (4.7.1) fails.
        Would you have any idea why I would be getting this issue based on your knowledge? I'm completely out of my league. I tried all the mechanical stuff, changing GPIO values in their script. Checking conections... etc. Nothing work. I've used a Mausberry in my other unit for over 5 years, and this one now about 9 months... everything was good until I moved up to the new image.
        Regards,
        JR
        BTW.. I use your script on my 3rd Retropie unit that's built into a MegaPi case. Works like a charm! Thanks!
        Here is the shutdown log... minus all the [OK...] statements.
        Stopped Dispatch Password Requests to Console Directory Watch
        Stopped Forward Password Requests to Wall Directory Watch
        Stopping Network Time Synchronization... Stopping Update UTMP about System Boot/Shutdown...
        Stopping Load/Save Random Seed...
        Stopped Load Kernel Modules.
        Stopped Load/Save Random Seed.
        Stopped Update UTMP about System Boot/Shutdown.
        Stopped Network Time Synchronization.
        Stopped Create Volatile Files and Directories. Stopped target Local File Systems.
        Unmounting /boot...
        Unnounted /boot.
        Reached target Unmount All Filesystems. System Check on /dev/disk/by-partuuid/97a6378b-01.
        Removed slice system-systemd\x2dfsck.slice.
        Stopped target Local File Systems (Pre).
        Stopped Create Static Device Nodes in /dev
        Stopped Create System Users.
        Stopped Remount Root and Kernel File Systems.
        Stopped File System Check on Root Device. Reached target Shutdown.
        Reached target Final Step.
        Started Power-off.
        Reached target Power-Off.
        Stopping Restore / save the current clock... 59.9899221 reboot: Power down
          cyperghost @jamrom2
          @jamrom2 looks like there is a overlay file loaded inside your /boot/config.txt
          Take a look for a entry like
          dtoverlay=gpio-poweroff
          and remove this
          • jamrom2J
            jamrom2 @cyperghost
            @cyperghost You nailed it! It was at the bottom of my config.txt...
            I had loaded both the Mausberry shutdown script and your script because this build I made will be for 3 different boxes I have. I just "#" it out as I will need it on my MegaPi Case.
            Thank you very much, it was the last item on my list and has been troubling me for months.
            Many kudos to you and Happy New Year!
            JR
            • cnotoC
              cnoto
              @cyperghost I am using your generic script above for a shutdown with a momentary button on a pi3a and Im seeing the following message:
              Kernel panic - not syncing attempting to kill init!
              Any thoughts why im seeing this?
              Many Thanks,
              • IdelacioI
                Idelacio @cyperghost
                @cyperghost
                Oops, sorry for the slow reply.
                Yup! That worked perfectly. Thanks! <3
                • ExarKunIvE
                  ExarKunIv
                  @cyperghost I have used this to shutdown my pi.
                  But i have come across a few posts saying that it can be used to shutdown a emulator or restart ES.
                  Can it be used to finishing killing xinit after exiting a game?
                    cyperghost @ExarKunIv
                    @exarkuniv as long as the call is
                    1. Runcommand.sh
                    2. Xinit
                    3. X Application
                      And all calls are children of the shell parent process then it is very likely that it will work. But never tested before
                    • ExarKunIvE
                      ExarKunIv @cyperghost
                      @cyperghost yes i have the command going through run command to lunch the game
                      here is my command that i have for my emulator.sh
                      dhewm3 = "XINIT:/opt/retropie/ports/dhewm3/dhewm3"
                      default = "dhewm3"
                      so i know that it calls it correctly. well i think it does
                      what do i need to do to set the shutdown script up. i have tried to follow your info as best as i could and i still get lost on it.
                      • quicksilverQ
                        quicksilver @ExarKunIv
                        @exarkuniv there is an issue with dhewm3 that the x window does not close properly after exiting the game. I was going to report it on the github page but never got around to it. It's likely to be a raspberry pi related issue or it could be because we aren't running a full desktop environment. Not sure if the dev would/could help.
                        There is a setting you can turn on via raspi-config that allows you to kill an x session using cntrl+alt+backspace. That was my workaround when trying to close dhewm3.
                        • ExarKunIvE
                          ExarKunIv @quicksilver
                          @quicksilver thanks for the idea. i managed to get my kill script to work and map my hot keys with Xboxdrv to start it so now my game/ports now exit quickly. but ill remember that if i end up needing it down the road
                          • V
                            vwgolfman
                            @cyperghost
                            Hello and thank you so much for all your hard work in creating the fantastic scripts that you do.
                            I have built a dual joystick controller with a Raspberry Pi 4 inside.
                            It is running Retropie 4.7.1
                            I have a button wired to pins 5 and 6 of the GPIO Header which shorts those pins when the button is pressed.
                            I would like to use this button as my safe shutdown button.
                            Please can you tell me whether your script will be good for this and if so should I install using...
                            wget -O - "https://raw.githubusercontent.com/crcerror/retroflag-picase/master/install.sh" | sudo bash
                            Many thanks once again for any help.
                            • WeirdHW WeirdH referenced this topic on
                              cyperghost @vwgolfman
                              @vwgolfman You are using the "wrong" script for this. Please visit https://github.com/crcerror/ES-generic-shutdown
                              There is a dedicated command line option for a single GPIO button. The Retroflag script is just a small subset of the one linked above.
                              Edit:
                              Did forget, I wrote small walk-through already here: https://retropie.org.uk/forum/topic/17415/multi-switch-shutdown-script
                              • IdelacioI
                                Idelacio
                                On resetting games with the reset button I'm getting the following error:
                                /home/pi/RetroPie/scripts/multi_switch.sh: line 63: kill: (####) - No Such Process
                                Where #### is the process number.
                                It also producses the following message on closing the process:
                                Killed
                                As it looks messy having persistant messages like these show between screens is there a clean way to hide them?
                                I don't want to completely prevent error messages showing as sometimes I do screw up so just these ones specifically. If it's all or nothing though I'll just have to accept that.
                                • V
                                  vwgolfman @cyperghost
                                  @cyperghost
                                  Thank you so much, your coding is fantastic and I am now using your safe shutdown script successfully!
                                  Could I please ask, is there a version which monitors the shutdown button continuously rather than polling it every second or so?
                                  • cnotoC
                                    cnoto
                                    @cyperghost I just used this script for a generic button on a zero 2 with no luck. Would anything be different about the pi zero 2?
                                    • AshpoolA Ashpool referenced this topic on
                                    • daniluxD
                                      danilux
                                      @cyperghost Hi sweet man :v, I wanted to know if you think that by modifying the paths in your install instructions I could make your script work on batocera, since it's emulation station same as retropie, I have a generic button I want to use to save shut down, any help is appreciated
                                      • ExarKunIvE ExarKunIv referenced this topic on
                                        BlackDraGoN 0
                                        I have got this error on my Raspberry pi 3b+:
                                        DTOVERLAY[error]: failed to open 'RetroFlag_pw_io.dtbo'
                                        Failed to read 'RetroFlag_pw_io.dtbo'
                                        What Can I do?
                                        The file is installed in the correct place, in fact, I installed it with the installer and checked that everything was correct, but the dto does not load it.
                                          mitu Global Moderator @BlackDraGoN 0
                                          @BlackDraGoN-0 That error is not from @cyperghost's script, the script doesn't have any references to that .dtbo file.
                                            BlackDraGoN 0
                                            My pins are always level=0 fsel=0 func=INPUT how can I change level 1 when I press a button?
