    Multi Switch Shutdown Script!
    shutdown scriptshutdown switchcyperghost
    272 Posts 40 Posters 132.8k Views
      cyperghost @julenvitoria
      @julenvitoria That's also not the problem
      You should use timer events. So you press the button (power button) if you release witihin 1.5 seconds you kill the emulators. If you don't realase the system power offs. Also doable ;) To led a LED glow
      use raspi-gpio set GPIONrLEDCONNECTED op dh
      to dim LED
      use raspi-gpio set GPIONrLEDCONNECTED op dl
      You can also export the port via bash command
         echo "$GPIO_poweronctrl" > /sys/class/gpio/export
          echo "out" > /sys/class/gpio/gpio$GPIO_poweronctrl/direction
          echo "1" > /sys/class/gpio/gpio$GPIO_poweronctrl/value
      You don't need to implent the code.... Use your python code and if power is going to suspend then use ./multi_switch.sh --es-poweroff command ;)
      It's a kind of swiss army knife.
      So it's up to you and your coding skills, to call this script with the commands it provides. The rest ... button timing, LED glowing is a question of your coding skills. My knowledge in python is very bare and I'm also a beginner in bash.
      To deal with the output of this script use this python sniplet
      import subprocess
      def run(command):
          output = subprocess.check_output(command, shell=True)
          return output
        cyperghost @cyperghost
        Created version 0.40
        Added NESPi+ Case!
        -- ORIGINAL FIRST POST! -- OUTDATED!! -- KEPT FOR NOSTALGICA
        I've lack of time so here is a base version of a script to detect PIDs of running emulator.
        This is the are bare (but) working sceleton of how emulators can be detected!
        You can download the script also from my github account: GITHUB - RETROPIE SHARES
        How does it work:
        1. This script uses runcommand.sh process as entrypoint
        2. It generates an array of child-PIDs called through runcommand.sh
        3. It shifts array backwards
        4. It sends TERM signal to all PIDs called by runcommand.sh (from newest to oldest)
        5. It waits if PID is finished
        6. Emulator is terminated
        So in practice:
        runcommand.sh [PID 1234] calls emulator lr-xxxxxx [PID 1236]
        So PID 1236 is terminated
        sometimes there are several script called
        runcommand.sh [PID 1234] calls bash file SCUMMVM [PID 1236] this calls SCUMMVM framework [PID 1345]
        So we TERM 1345 and wait for closing, TERM 1236 and wait for closing!
        The advantage here is... there is no need to hook /dev/shm/runcommand.log and read out used emulator. We need just an emulator call via runcommand.sh ;)
        @meleu @mediamogul @Drakaen391 @caver01
        Let us improve the shutdown scripts ;)
        #!/bin/bash
        # Shutdown Script Emulator Sceleton
        # by cyperghost for retropie
        # Initial release: ??? Don't know January 2018?
        # 04/19/18 Release in RetroPie forums
        # 04/20/18 julenvitoria introduced kill -9 signal for emulators
        # This function is called still all childPIDs are found
        function getcpid() {
        local cpids="$(pgrep -P $1)"
            for cpid in $cpids;
            do
                pidarray+=($cpid)
                getcpid $cpid
            done
        # Abolish sleep timer! This one is much better!
        function smart_wait() {
            local PID=$1
            while [[ -e /proc/$PID ]]
            do
                sleep 0.05
            done
        # Our entrypoint! RUNCOMMAND is alpha, emulator is OMEGA
        motherpid="$(pgrep -f -n runcommand.sh)"
        # if there is no runcommand.sh running then exit
        [ "$motherpid" ] && getcpid $motherpid || exit
        # Reverse array and do your TERM job
        for ((z=${#pidarray[*]}-1; z>-1; z--)); do
            echo "Terminate PID ${pidarray[z]}"
            kill -9 ${pidarray[z]}
            smart_wait ${pidarray[z]}
        done
          @julenvitoria I implented the python script from the NESPi+ to work with my script. Works like a charm - python is very powerfull together with bash.
          So here is a full working example of how to integreate...
          For explaination how this works.
          The python script waits for a button event (the GPIOZERO Libery does this all in the background). A button is triggered now I as multi_switch.sh to output the ES-PID (to check if ES is running or not). If the result is a integer greater than 0 than it's a boolean true and we can shutdown ES with `./multi_switch --es-poweroff´ command (it closes running emulators, exits ES and initiates a shutdown) so all metadata is saved.
          If the answer is 0 we've got a boolean false and we use the regular shutdown.
            julenvitoria Banned @cyperghost
            @cyperghost Hi! Sorry but I was very busy these days... tonight or tomorrow I will upload the code that I use for you to see it. Yes, Python script plus bash is a powerful weapon !!
              @cyperghost Here are the two scripts... the first pastebin is a script in python and is originally created by George Ilyes (https://github.com/gilyes/pi-shutdown/blob/master/pishutdown.py) and is modified by PlataKoway and me to make it even more complete. Through this script I call version 0.07 of your script (the second one) in order to kill the process of the emulator that is running and then I close emulationstation in a safe way.
              https://pastebin.com/4FgsKK06
              https://pastebin.com/LpfaZh9J
                cyperghost
                @julenvitoria There are some things that can be improved ;)
                1. Primary: If you use python then make use of interrupt then you can avoid the while(true)-loop.
                2. Secondary: I would rather do a ES-restart than a system reboot
                3. Secondary: I would rather use the poweroff button for an poweroff at short press and would use the 3 second timer to do a restart/reboot ;)
                4. Primary: The killall emulationstation will work in most cases but you will fail if you have scraped large amount of data. Because if after 5 seconds a shutdown is initiated the file system will be set to read only and you will loose data.
                5. Secondary: You use lots of sudo commands. You call the k.script with sudo for ex. this isn't necassary as ES is called by user pi, morover if you call the script via rc.local you are user root (so even the sudo shutdown can be shortend to shutdown only) or if you call it via ES autostart you are user pi, and then sudo shutdown is needed ;)
                All in all if you are happy with your setup and it works it is okay ;)
                Imho take a look to Point 1, this is one of the improvements python can handle at ease ;) Because with this setup it really doesn't matter if you use python or bash ...
                Take a look at this example here - you will see, there is no while-loop, because you can use interrupts. Your script uses polling :) Please don't take this as an offence.
                  @cyperghost Oh, thanks very much! I'll take a look to the link. You can be calm, I always receive in a good way a constructive criticism!! My skills of python are not very good but I am learning... :D
                    @julenvitoria I'm with you.
                      gollumer
                      I just got a nespi+ case, and installed your script (I never installed the one from nespi). It restarts ES fine, but I don't think it's doing the safe shutdown correctly. When I press the power button, it goes straight to a black screen and shuts off. I don't see the screen output doing it's safe shutdown processes.
                      I used the instructions here to install: https://retropie.org.uk/forum/topic/17461/nespi-case-reset-works-power-doesnt/16
                      I did install raspi-gpio as well.
                      If I run this at the command line, I get a pid: ./multi_switch.sh --es-pid
                      I tried running the shutdown command from the command line as well (./multi_switch.sh --es-poweroff), but it goes straight to a black screen as well...not a safe shutdown.
                      What could be wrong?
                      I have an RPi3, running RetroPie 4.3.
                        cyperghost @gollumer
                        @gollumer Well... did you checked if your favourites are saved? I regard your feedback as the script is doing it's work fine in a NESPI+ case. Let me explain: I tested several times on my system (It's exactly like yours: RPi3 and RetroPie 4.3) and I was able to save favourites and even scraped data with the switches --es-poweroff you used, too. So I see no fails or flaws. The shutdown is incredible fast because it terminates each session as long as the PIDs are not valid anymore.
                        The trick is, that if the ES binary received the -TERM signal annother script (it's internal in ES) takes over and initiates the shutdown. So it behaves exactly as you restart/reboot/shutoff via ES's QUIT from Main Menu!
                        You can view the script here nano /opt/retropie/supplementary/emulationstation/emulationstation.sh - this is responsible for restart ES and other system shutdowns.
                        But please tell me if following things are working (because NESPi+ is still WIP, caused by I don't have this device here in range for testing, so everything is done with code reading and some photographs of the connectivity to the GPIO heads)
                        1. You press POWER ON and the system starts, LED will glow if script is loaded
                        2. You press POWER OFF inside ES (even with emulators running) and the system performs a save shutdown (with metadata, favourites .... saved) - LED blinks 4 times and stays off
                        3. You press RESET with emulator running and you will be returned to ES
                        4. You press RESET within ES and it restarts ES (NO REBOOT!!!)
                        Thanks for your support!
                          gollumer @cyperghost
                          @cyperghost said in Multi Switch Shutdown Script!:
                          Thank you for your response. Here are the answers to your questions:
                          1. Yes, POWER ON = the system starts, and LED lights up.
                          2. No, POWER OFF inside ES did not perform a safe shutdown, no metadata saved. The LED blinked 4 times, then the screen went black. Prior to pressing POWER OFF, I had added a game to my Favorites collection, and verified that it was there. After turning off, then turning back on, the game was no longer in my Favorites collection.
                          3. No, RESET with emulator running does nothing.
                          4. Yes, RESET within ES (but not emulator running) restarts ES without rebooting.
                          So, as you can see, it's partially working, but not completely (and the most important one...#2 (safe shutdown)...is not working.
                            @gollumer Okay thanks.
                            Script works!
                            It is essential to set the switch in the NESPi+ CASE in ON position!
                              gollumer
                              Update: I opened up the nespi+, turned the switch from ON to OFF, then back to ON, and now it's saving metadata! Seems that it wasn't completely in the ON position. Also, RESET from within an emulator now works as well. (I think the issue with that before was I was just pressing it quickly, not holding it for a second...)
                              So, problem solved.
                                @gollumer Perfect! As I said - some people like @meleu @TMNTturtlguy and me spent tons of time to elaborate a working solution! So I was pretty sure the script works!
                                Annother questions:
                                Do you have a fan installed in your system?
                                Do you load the script per autostart.sh or via rc.local? Both versions do work but I prefer always the autostart solution.
                                  gollumer
                                  Yes, I have a fan. I installed it on the 3.3v connector instead of 5v so that it's not as loud. I'm loading the script in autostart.sh.
                                    cloudlink
                                    I installed this script with my Nespi+ case and it works perfectly!
                                    I also have a fan. If I plug it into a 3.3v pin, what scripts are available to control it?
                                      @gollumer Good catch ;)
                                      But you have to connect it to the FAN connection position in the NESPi+ case
                                      Even if it's loud! Directly connected to 3,3V will affect nothing
                                      I assume it's not powered down even the Raspberry is shutdown.
                                      Therefore... can you exit ES to terminal and then write:
                                      raspi-gpio set 4 op dl
                                      This will powerdown GPIO 4 and may also shuttoff the fan!
                                      But please exit ES to terminal first. I don't want that you will loose data as I don't know what happens.
                                      If this works you can uncomment line 184 from script!
                                      and then NESPi+ is 100% working
                                          # PowerOff LED, Poweroff PowerCtrl
                                          raspi-gpio set $GPIO_lediodectrl op dl
                                      #    raspi-gpio set $GPIO_poweronctrl op dl #Really have no clue what it does!
                                      # Initiate Shutdown per ES
                                      @cloudlink
                                      Same question: I think the fan isn't powered off so it will always run.
                                      Maybe that's the magic of GPIO4!
                                        cyperghost @cloudlink
                                        @cloudlink said in Multi Switch Shutdown Script!:
                                        Then you can use raspi-gpio to powerdown that PIN - if you use a GPIO that let's the fan run! But this is not the recommended way ;) Usually those devices are connected to 5V rail (because this delivers 2.5A!) and a GPIO controls a switch to powerdown/poweron that device. Keep in mind ... the 3.3V GPIO rail only delivers 0.10 or 0.05A! That's much enough for a few LEDs and lots of microcontrollers but maybe not enough for a fan.
                                        But I assume the NESPI+ fan connector itself is switchable. Because I've really NO idea why we need GPIO 4 (POWERONCTRL?)
                                        If you want to make the fan switchable I would recommend you:
                                        1. Try the connector into the case, this is maybe switchable (maybe GPIO 4 will do it's job)
                                        2. Try to connect your fan to 5.0V or 3.3V line (that's PIN1 = 3.3 and PIN2,4=5V) and then use a MOSFET connected to a GPIO that switches fan on or off. Therefore raspi-gpio can be used.
                                          gollumer
                                          Lol. Yeah, I originally had the fan connected to the fan connector, but recently changed it due to the noise. You're right: the fan doesn't shut down. I'm not at home right now, but when I get home I'll try the command you suggest (raspi-gpio set 4 op dl) from the terminal and see what happens.
                                            cloudlink
                                            My fan is connected to GPIO pin 17. Will this make it so the fan runs when the Pi is on but the fan is off when the Pi is off?
