    Multi Switch Shutdown Script!
    shutdown scriptshutdown switchcyperghost
    272 Posts 40 Posters 130.9k Views
      cyperghost
      @denisuu Take a look here SHIM ON OFF cut power PART 1
      Use this script and set the correct Pins in script. This works
      denisuuD 1 Reply Last reply Reply Quote 0
      • denisuuD
        denisuu @cyperghost
        @cyperghost
        I tried for more than an hour I really can't get this to work.
        In THIS tutorial: Do I copy the content of SHIM ON OFF - PART ONE in part 2.a or 3.a?
        I'm also confused with the pin numbers, in the other tutorial he uses pin 5 and in your script it's pin 4 or am I confusing the pin to power down with the button?
          cyperghost @denisuu
          @denisuu I don't use OSMC so make sure the directory /lib/systemd/system-shutdown/ is available (I think it is available)
          So in your tutorial follow steps till 2b
          1. sudo nano /etc/rc.local
            3.1 add above line exit 0 python /home/osmc/shutdown.py &
            3.2 or /home/osmc/shutdown.py & alone can also work ;)
          2. setup script according to link from me
            4.1 change led_pin from 17 to 14
            4.2 poweroff_pin = 4 is okay
          No... 5 is physical pin 5 = GPIO 3 so magic are the lines import RPi.GPIO as GPIO ..... GPIO.setmode(GPIO.BOARD) in the python script.
          • denisuuD
            denisuu @cyperghost
            Thanks for the help, really appreciate it!!!
            It's partially working now, now it goes to sleep and the fans keep spinning like in the original script.
            I actually have a Retroflag SUPERpi case (on the other 2 scripts it dind't make a difference).
            the power-switch acts a little funny now. Up is reboot and down is sleep.
            All steps done: https://pastebin.com/4QcLQY7M
            Edit: It's reacts exactly the same on Raspbian.
              cyperghost @denisuu
              @denisuu Does the LED blink 3 times? You have to make the gpio shutoff script executable with chmod command. This is essential forget this to mention
              Edit it is command
              sudo chmod +x /lib/systemd/system-shutdown/gpio-shutoff
              • denisuuD
                denisuu @cyperghost
                Yes it blinks 3 times and powers off then after af few seconds turns on again,
                or goes to sleep (depending on the possition of the switch).
                I did make the script executable I forgot to add it to the pastbin. (added it now)
                  cyperghost @denisuu
                  @denisuu are there any other scripts running? It is a bit hard to guess but you can try to use the original fan_shutdown script. Please install raspi-gpio with sudo apt-get install raspi-gpio
                  • denisuuD
                    denisuu @cyperghost
                    Ok I removed the old script on Raspbian and installed yours, it works perfectly now!
                    Only OSMC left, it's really sad it doens't work on OSMC since that's what I use my pi most often for. OSMC doesn't find the package raspi-gpio or npm. Can I just disable the FAN on that partition? Or get raspi-gpio from somewhere else?
                    Raspbian:
                      296  cd /home/pi/
                      297  ls -alF
                      298  rm reset.py
                      299  rm shutdown.py
                      300  rm /lib/systemd/system/shutdown.service
                      301  apt install raspi-gpio
                      302  mkdir /home/pi/scripts
                      303  cd /home/pi/scripts
                      304  wget https://raw.githubusercontent.com/crcerror/ES-generic-shutdown/master/multi_switch.sh && chmod +x multi_switch.sh        r/multi_switch.sh && chmod +x multi_switch.sh
                      305  ls -alF
                      306  sudo nano /etc/rc.local     (/home/pi/scripts/multi_switch.sh --nespi+ & before exit 0)
                      307  cd /lib/systemd/system-shutdown/ && sudo wget https://raw.githubusercontent.com/crcerror/ES-generic-shutdown/master/shutdown_fan && sudo chmod +x shutdown_fan        nt.com/crcerror/ES-generic-shutdown/master/shutdown_fan && sudo chmod +x shutdownfan
                      cyperghost @denisuu
                      @denisuu I think in OSMC it is easily possible to add that function, too. You can try wiringPi instead - I think that should be available. So every call to raspi-gpio must be translated to a wPi call.
                      EDIT:
                      I think you should use sudo apt-get install build-essential and then you can further start your build
                      • denisuuD
                        denisuu @cyperghost
                        I deleted half of the scipt and it still works, would it be possible to delete everything I don't need from this? That would make it a lot easier to translate it to WiringPi, since I don't understand half of what the script does.
                          cyperghost @denisuu
                          @denisuu You can delete 95% if the script and it will still work. Instead of the raspi-gpio try to translate to wpi calls. Did you try to compile raspi-gpio? https://github.com/RPi-Distro/raspi-gpio
                          • denisuuD
                            denisuu @cyperghost
                            @cyperghost I'll try that though I'm pretty new to Linux so that would be a first time compiling anything, good way to learn!
                            This the most I could delete without breaking functionality. Is it difficult to add the reset button to just reboot?
                            Retroflag_Raspbian-Shutdown.sh
                            Danke schön!
                              cyperghost @denisuu
                              @denisuu yes that is a stripped down version. Now use the if clause in line 28 and write your reboot command in. You can further strip down this if you want. Take care about the reset value I am not sure what it's default is. 0 or 1 just pretest with echo command.
                              • denisuuD
                                denisuu @cyperghost
                                I compiled raspi-gpio on OSMC and the script is working now!!! I wouldn't know how to further strip this down, it's a miracle I even got this far!
                                The onlything left to do is the reboot button.
                                When it's finished is it ok if I put them on Github? All credits to you ofcourse!
                                • denisuuD
                                  denisuu
                                  It was just as simple as putting sudo reboot on the line you said! It seems the button doesn't work every time, sometimes I have to press twice but good enough! Maybe it's just the case...
                                  I put this here:
                                  https://github.com/Denisuu/OSMC_NesPi-SuperPi_Safe-Shutdown
                                  I haven't linked it anywhere so if you have any objections let me know!
                                    cyperghost @denisuu
                                    @denisuu said in Multi Switch Shutdown Script!:
                                    Nice job. This is IMHO the best solution to go
                                    Do as you like. I take a look to your git looks good.
                                    Excuse me for my late reply I was on vacation and the internet connection was terrible bad so there was just room for some phone messaging and email. For goodness SMS worked very good ;)
                                      cotton
                                      I am just re-doing a new OSMC installation with Retropie embedded in it so I thought I would get a retroflag and finally put it in a case!
                                      @denisuu
                                      I followed your instructions on your git page. I have a question on step 1) You said I could run the command for OSMC as a one liner, but I got permission denied, I just had to run it as sudo in pieces; that worked until i got to the last command "make install". I get the following message:
                                      osmc:/usr/src/raspi-gpio$ make install
                                      gcc -DPACKAGE_NAME=\"raspi-gpio\" -DPACKAGE_TARNAME=\"raspi-gpio\" -DPACKAGE_VERSION=\"0.2\" -DPACKAGE_STRING=\"raspi-gpio\ 0.2\" -DPACKAGE_BUGREPORT=\"serge@raspberrypi.org\" -DPACKAGE_URL=\"\" -DPACKAGE=\"raspi-gpio\" -DVERSION=\"0.2\" -I.     -g -O2 -MT raspi-gpio.o -MD -MP -MF .deps/raspi-gpio.Tpo -c -o raspi-gpio.o raspi-gpio.c
                                      /bin/bash: gcc: command not found
                                      Makefile:361: recipe for target 'raspi-gpio.o' failed
                                      make: *** [raspi-gpio.o] Error 127
                                      Am I missing something?
                                      • denisuuD
                                        denisuu @cotton
                                        I'm not sure, I tried it a couple of days ago and it was working.
                                        Maybe you can try and compile it from here? https://github.com/RPi-Distro/raspi-gpio
                                          cotton
                                          Ok,
                                          I reinstalled Retrosmc and that made it work. Works like a charm; if I had a way, id buy you both a drink.
                                            cyperghost @denisuu
                                            @denisuu I lift your OSMC modification into first posting. Glad you compiled raspi-gpio to OSMC
