    SPI activate Problems
    spitftili9341blacklistconfig menu
    5 Posts 3 Posters 1.1k Views
      RatWolf6
      Hallo at all,
      im sorry for my worse spelling and if this Thread is already diskused.
      But im not a native speaker ;)
      Now my question:
      I have installed the Retropie for the RPI0. I want to use an ILI9341TFT screen via SPI and found some tutorials. inkluding this one: https://www.xgadget.de/anleitung/2-2-spi-display-ili9341-am-raspberry-betreiben/
      The only thing is, that these tutorials all says that i must activate the SPI. But in the Advanced Options are no SPI config.
      For this reason i want to activate this point and found this tutorial from adafruit:
      https://learn.adafruit.com/adafruits-raspberry-pi-lesson-4-gpio-setup/configuring-spi
      But than cames the next problem, if i open the blacklist.conf, it says that this File would be new.
      Can anybody help me to aktivate the SPI?
      Thanks alot befor.
      Kind regards
      Ralf
        mitu Global Moderator @RatWolf6
        @ratwolf6 said in SPI activate Problems:
        If the file doesn't exist, then you can ignore it - it means no module has been blacklisted.
          RatWolf6
          @mitu said in SPI activate Problems:
          But its still not in the advanced options an the modprobe also dont return anything... im helpless :)
            RatWolf6
            Nobody here who has an idea?
              juj
              There is another driver project for ILI9341 based SPI displays https://github.com/juj/fbcp-ili9341 that you can try, if you're still working on the project. That one is a full standalone solution that does not utilize modprobe or the kernel SPI driver. Installation instructions are at https://github.com/juj/fbcp-ili9341#building-and-running
