    Need Help Configuring D-Pad to act as Analog Stick in Arcade Games
    arcadefbaanalog stickdpad
    14 Posts 5 Posters 8.8k Views
      AirFreshNerd
      I'm trying to setup 8bitdo controllers(or any SNES controllers) to play arcade games that look for the analog stick. I know I can edit the autoconfig in opt/retropie/configs/all/retroarch/autoconfig for the specific controller, but I would like a global setting for any controller that gets plugged in without analog sticks to just work with the arcade games. Is this possible? Any guidance would be appreciated!
      This is the code I used for the autoconfig btw:
      input_l_y_minus_axis = "-1"
      input_l_x_plus_axis = "+0"
      input_l_y_plus_axis = "+1"
      input_l_x_minus_axis = "-0"
        barbudreadmon
        I always thought the "User X Analog To Digital" option in "quick menu > controls" was actually doing this, but it seems it actually does the reverse. To be perfectly honest, don't bother too much with this, at best you'll end up with crappy controls if you manage to play those games with d-pad.
          dankcushions Global Moderator @AirFreshNerd
          @airfreshnerd you could map the dpad directions to their respective analog directions during https://retropie.org.uk/docs/First-Installation/#configure-controllers
          B A 2 Replies Last reply Reply Quote 0
            barbudreadmon @dankcushions
            @dankcushions said in Need Help Configuring D-Pad to act as Analog Stick in Arcade Games:
            It could do the trick, most likely you'll also have to use the option i mentioned above if you do that (since digital game controls won't work with analog sticks without it)
              dankcushions Global Moderator @barbudreadmon
              @barbudreadmon my memory is that via the linked tool you can bind the dpad direction to both. eg, left on your dpad bound to retropad digital left, AND retropad analog left.
                AirFreshNerd @dankcushions
                I tried this, however when I try to configure the "left thumb" it says button already taken.
                I will try again later and report back.
                  @airfreshnerd left thumb i believe is when you click in the stick on many analog controllers - you don't need to bind this one - just hold a button down to skip it :)
                    Oh I thought that's what you meant about your previous post about mapping the dpad directions to their respective analog directions.
                      @airfreshnerd what i mean is, if you look at:
                      what i mean is, when it asks you to bind left analog up, you press dpad up, and when it asks you to bind d-pad up, you also press dpad up. and so on...
                        Correct! However I'm saying that when I try to do that it says the button was already chosen and I cannot select it. It will not let me choose up on the dpad, then up on the dpad for the analog mapping.
                        • markwkiddM
                          markwkidd
                          This will be easier to accomplish with the new remapping system in RetroArch 1.7.2 -- probably RetroPie 4.5 though. Cold comfort today I know.
                          mediamogulM dankcushionsD 2 Replies Last reply Reply Quote 0
                            @airfreshnerd oh, hmm, you're right!
                            https://github.com/retropie/EmulationStation/blob/master/es-core/src/guis/GuiInputConfig.cpp#L386
                            this seems like a bad feature to me - i can see why you'd want one button/direction to be multiple retropad button/directions, although i can see also how it could get people into a mess if they didn't know they were doing that. i'll raise this internally - thanks!
                              mediamogul Global Moderator @markwkidd
                              @markwkidd said in Need Help Configuring D-Pad to act as Analog Stick in Arcade Games:
                              I was thinking the same thing and hoped you'd chime in with a comment confirming that. As nice as a unified set of controls has always been with RetroArch, I've previously found it's ability to remap very limited. I look forward to trying it out.
                                dankcushions Global Moderator @markwkidd
                                how would it work with this specific example? i don't know what the new retroarch stuff does, yet, so this will be an interesting example.
                                i'm thinking for retropie's initial binding, we give the users each abstracted retropad button, and they press the associated physical button they want to use for that, which seems logical so far. how would retroarch 1.7.2 change this approach?
