    Audio problems
    help please
    13 Posts 4 Posters 1.8k Views
    • H3rmitPl4ysH
      H3rmitPl4ys
      So I am having audio trouble with n64, I am using USB speakers which I have setup and they work on all the other systems. I'm using mupen64plus-gles2rice-highres but I get no audio. I have tried other defualt emulators and the only one I get audio is on lr-mupen64plus but that is really pixelated. Litterally every other emulator gets NO audio except lr-mupen64plus. What should I do?
      mituM quicksilverQ 2 Replies Last reply Reply Quote 0
        mitu Global Moderator @H3rmitPl4ys
        @h3rmitpl4ys Start with https://retropie.org.uk/forum/topic/3/read-this-first and give us more details about your setup.
        H3rmitPl4ysH 1 Reply Last reply Reply Quote 0
        • retroprogrammerR
          retroprogrammer
          @H3rmitPl4ys It could be the ROM that you are using? and don't forget that the RP3 isn't a pc and it wont run N64 or higher to the quality that you are looking for.
          Here is me converting the original Xbox for a case:
          https://retropie.org.uk/forum/topic/15232/converting-original-xbox-into-case-for-raspberrypi/15
          Check out my GitHub: https://github.com/retro-programmer
          • H3rmitPl4ysH
            H3rmitPl4ys @mitu
            @mitu My raspberry Pi is model B+, my retropie version is 4.4, and all of my USB devices are my keyboard and USB speakers.
            • H3rmitPl4ysH
              H3rmitPl4ys
              @retroprogrammer Yes I know that, but my Raspberry pi runs it fine. It's just the audio. I get audio on the lower versions but on higher emulators I get no audio.
              • retroprogrammerR
                retroprogrammer
                Yes I understand, the emulators can run the game but just can't seem to get any audio out
                • H3rmitPl4ysH
                  H3rmitPl4ys @retroprogrammer
                  @retroprogrammer Exactly! Now the question is, what should I do?
                  • quicksilverQ
                    quicksilver @H3rmitPl4ys
                    @h3rmitpl4ys have you tested systems other than N64?
                    • H3rmitPl4ysH
                      H3rmitPl4ys @quicksilver
                      @quicksilver Yes the audio works on Snes, Genesis, nes, ect.
                      • quicksilverQ
                        @h3rmitpl4ys did you try setting mupen64plus_audio = "0" like I suggested in the other thread you posted in?
                        H3rmitPl4ysH 2 Replies Last reply Reply Quote 1
                        • H3rmitPl4ysH
                          @quicksilver Doesn't that force the audio out the 3.5mm jack? Because I use USB speakers. No the jack.
                          • H3rmitPl4ysH
                            @quicksilver Never mind! I actually just tried it out, and it works! Thanks for your help!
                            • quicksilverQ
                              @h3rmitpl4ys glad it worked for you!
