    Help with script to maintain bluetooth connection
    13 Posts 5 Posters 6.0k Views
    • JasperSladeJ
      JasperSlade
      I've got a Raspberry Pi 3 loaded with RetroPie 3.8. I connected a cheap bluetooth gamepad that I was able to connect via bluetoothctl.
      My issue is that if I walk away from the RPi for a few minutes, the gamepad goes to sleep, and will not reconnect when powered back on, forcing me to drop back to the command line and use bluetoothctl to reconnect.
      I'd really like help writing a script that will periodically check to see if the gamepad is connected, and if not, attempt to reconnect.
      Any help would be greatly appreciated!
      ~Jasper
        Might want to try these instructions, use the 8bitdo instructions
        https://github.com/RetroPie/RetroPie-Setup/wiki/Setting-up-a-Bluetooth-controller
        • JasperSladeJ
          JasperSlade
          I followed those instructions exactly, and have had 100% success connecting the gamepad at startup. My issue is when the gamepad goes to sleep (say I get up to help my wife with something) when I come back and my gamepad has powered down due to inactivity, when I power it back up, it doesn't reconnect to the Pi.
          At this point I have to either reconnect via the command line, or reboot the Pi.
          ~Jasper
          • JasperSladeJ
            JasperSlade
            I think I may have found a solution. If someone with a little more knowledge than me can take a look at this and let me know what they think. Adding this to my already existing startup script:
            #!/bin/bash
            address="XX:XX:XX:XX:XX:XX"
            while (sleep 1)
            do
            connected=$(hidd --show) > /dev/null
            if [[ ! $connected =~ .${address}. ]] ; then
            hidd --connect ${address} > /dev/null 2>&1
            fi
            done
            ~Jasper
            lilbudL 1 Reply Last reply Reply Quote 1
              I suffer with this problem as well.
                lilbud @JasperSlade
                @JasperSlade Did you create those files listed in the guide?
                • JasperSladeJ
                  JasperSlade
                  So far I've done the following:
                  Created: sudo nano /bin/connect-bluetooth.sh
                  Added the following text:
                  #!/bin/bash
                  sudo bluetoothctl << EOF
                  power on
                  connect [MAC Address]
                  exit
                  EOF
                  Made the file executable: sudo chmod +x /bin/connect-bluetooth.sh
                  Created a service file: sudo nano /etc/systemd/system/connect-bluetooth.service
                  [Unit]
                  Description=Connect Bluetooth
                  [Service]
                  Type=oneshot
                  ExecStart=/bin/connect-bluetooth.sh
                  [Install]
                  WantedBy=multi-user.target
                  Enabled the service file: sudo systemctl enable /etc/systemd/system/connect-bluetooth.service
                  At this point, my gamepad connects at startup flawlessly. When the gamepad powers down, it fails to reconnect.
                  I'm hoping that if I add the following text to my connect-bluetooth.sh, it will continually check for my gamepad, and reconnect when needed. Hopefully that is, it looks like the below code is for an older version of RetroPie, one that utilizes bluez, where as my build has bluetoothctl instead
                  (#!/bin/bash
                  while (sleep 1)
                  do
                  fi
                  done)
                  ~Jasper
                    In /bin/connect-bluetooth.sh, you did put the Mac Address where it says right?
                    • JasperSladeJ
                      JasperSlade
                      Yes. 85:55:08:78:17:D1
                      ~Jasper
                      • JasperSladeJ
                        JasperSlade
                        I found my solution. I made the following changes (in bold) to my /bin/connect-bluetooth.sh file.
                        #!/bin/bash
                        while (sleep 30)
                        do
                        power on
                        exit
                        EOF
                        done
                        You can change the sleep value to whatever you'd prefer. 30 seconds seemed to work out fine for me. If i start to get impatient, I'll change it down to 15.
                        ~Jasper
                        RionR meleuM 2 Replies Last reply Reply Quote 1
                        • RionR
                          Rion @JasperSlade
                          @JasperSlade said in Help with script to maintain bluetooth connection:
                          #!/bin/bash
                          while (sleep 30)
                          do
                          power on
                          exit
                          EOF
                          done
                          Nice solution! Could you add this to the wiki page? Setting up a Bluetooth controller
                          FBNeo rom filtering
                          Mame2003 Arcade Bezels
                          Fba Arcade Bezels
                          Fba NeoGeo Bezels
                            meleu @JasperSlade
                            It'll sleep for 30 seconds during the boot?
                            • herb_fargusH
                              herb_fargus administrators @Rion
                              @Rion it's a wiki. Anyone can add to it provided the content is valid.
