    4 Player RetroPie Issues
    4 playerarcade sticksarcaderetropie4 players
    5 Posts 3 Posters 901 Views
    • allenpieA
      allenpie
      Hello
      Long Story Short; I have 4 working controllers; I have my sanwa arcade sticks working perfect [Player 1] [Player 2] See pic
      I also have 2 wireless technology with 30-foot range fake X box clones; setup as player 3 and player 4
      I can get all 4 working just fine;; if it's a 4 player game
      The issue I have is sometimes I want my player 1 and player 2 to be the controllers and not the arcade sticks; It's a shared arcade and sometimes people want to use the controllers and not the arcade sticks for some games. I don't know how to default this without losing my controller defaults.
      So if a friend wants to run the controller they can and the arcade sticks wouldn't be in use.
      Can you map is so the player 3 and player 4 controller can also be the player 1 and player 2 arcade stick setup?
      I'm sure there is like a config file to do this or set up defaults ect? Is anyone else doing this?
      https://gyazo.com/d79ee81da60f5cf3841209bda10fd552l
      Here is a pic before it was all done
      Thanks for the help
      Retro Pie and Chill
      • allenpieA
        allenpie
        Is anyone using controllers and arcade sticks as player 1 and 2 on both or does it not work that way
        Retro Pie and Chill
        robertvb83R 1 Reply Last reply Reply Quote 0
        • robertvb83R
          robertvb83 @allenpie
          @allenpie it sounds like the Joystick Selection Tool is for you.
          you cannot assign both Controllers to player 1/2 simultanously but you can quickly swich between Joysticks via easy menu entry
          My full size arcade cabinet Robotron vs. Octolyzer
          allenpieA 1 Reply Last reply Reply Quote 0
          • allenpieA
            allenpie @robertvb83
            @robertvb83 What menu option?
            Retro Pie and Chill
              mitu Global Moderator @allenpie
              @allenpie Install the Joystick Selection tool from the link provided and you'll have an extra menu entry in the RetroPie menu for you to configure the controller/player mapping.
