    Pathfinder for Custom Collections - correct pathes for custom collections
    cyperghostcustomcollectionsshare
    28 Posts 2 Posters 6.6k Views
      cyperghost @thelostsoul
      @thelostsoul said in Pathfinder for Custom Collections - correct pathes for custom collections:
      But what about sfiii, if I don't have this game? What if I don't want it to recognize as sfiii2 or sfiii3. What should have i selected then?
      Okay ... I should implent a working "Do nothing" or "Proceed to next selection" button ;)
      If you don't have a sfiii file then it's clear what happens.
      It does not find the right file. Next Step is search for sfiii* files and guess... tada it will show sfiii2 and and sfiii3 ;) So there are several things that I can do...
      I can add a working button or just add an "Ignore this entry" into the selection itself ;)
      Again about the inline writing. It took me hours to find out how to use the sed command. It's easy to search for some words to replace but file pathes can be a bit different because there are signs in like the slash that are control characters ;) So the easiest way was - instead to replace the string by occourance - to replace the line were the string occours ;) Is the more effictive way because I wanted to avoid using temporary files!
      About the filenaming. Maybe real dates would be better ;)
      like "2018-05-21--21-50-10-custom-super-mario.cfg"
      Would be more clearer but I was in hurry as I did a backup solution, so I used just the time gone in seconds since 1970.
      thelostsoulT 1 Reply Last reply Reply Quote 0
      • thelostsoulT
        thelostsoul @cyperghost
        @cyperghost Yes, sed isn't easy to work, because of all the RegEx rules. I was once working on something different with heavy RegEx manipulations, so RegEx got my favorite function (back then, it was AutoHotkey on Windows :D). But why don't you want work with temporary files? In case something happens or I abort the process, nothing should have changed. Wait a second. And what is "Don't change !" doing? Shouldn't the file stay original afterwards? I think it changed the original file.
        To be more clear, imho the options should be named to <Select>, <Stop now>, <Revert changes> and <Ignore this entry>.
        📜 RE/SET: 100 SNES Games for your RetroPie, 🎁 Share your hidden gems and insider tips
          @thelostsoul Made new updates....
          You can select between advanced and simple search (I recommend simple in first try and then use advanced search in second try)
          In ROM selection screen, Exit works, Skip works, Select works
          Help does not work ... will display just a message box ;)
          Newest version is here
          • thelostsoulT
            thelostsoul
            I have a real world use for your script now. I decided to change a lot of roms at NES and SNES, mostly from European to US version, because of 60 Hz. And now, many of my collections aren't up to date. But here comes your script and now they are. I have updated some of my collections now and I don't see any problem. Using Simple search. It works so far and it saved me some time, instead of manually checking every single file!! So a big thank you.
            Edit this line: I forgot about the executable bit. To use the script without typing bash in front, you need to give the executable right for the script file with "chmod +x filefind.sh". Then for the starting script you need to type "./filefind.sh". Maybe add this info.
            If the script is done, the screen don't change on my setup. It still shows the last menu entry like this:
            As a sidenote, I use PuTTY client.
            Ok, here is something else in my Action Adventure collection:
            Found write with sed: /home/pi/RetroPie/roms/gbc/Legend of Zelda, The - Link's Awakening DX (G) [C][!].gbc -- /home/pi/RetroPie/roms/gbc/Legend of Zelda, The - Link's Awakening DX (G) [C][!].gbc
            It is the same path, so no need for sed right? Is this a "BUG" or do I miss something? Same thing happened with "Kirby's Block Ball (U) [S][!].gb". Oh and with two other game boy games too. So it must be a game boy thing here, maybe because of the file endings. Or maybe not, it happened with snes entries too. Here entries when sed was used, while it was exactly the same:
            Clock Tower (J) ]T+Eng1.01_AGTP].smc
            Live A Live (Japan) [En by Aeon Genesis v2.0Deluxe].sfc
            Alcahest (J) [T+Eng1.0_FH].smc
            and some more. All entries like these above.
            Another thing. It did not find alternative for
            Mario Bros. Classic (E) [!].nes
            while I have
            Mario Bros. (JU) [!].nes
            It is simple mode, I know, but after using simple mode, the entry is gone. Afterwards using advanced mode does not help. So user never knows when to use advanced mode. Maybe a function to restore a backup then?
              I hunted that down. Please update the script... it's an error in find routine! The find command seems to be unable to hunt ] chars. So I escaped that.
              You can try manually. Go to that directory and use find -name "Clock Tower (J) ]T+Eng1.01_AGTP].smc" and you will get no result. Type find-name "Clock Tower (J) ]T+Eng1.01_AGTP*" will get the result. Now type "Clock Tower (J) ]T+Eng1.01_AGTP/].smc"` and you will get a result. Don't ask me why!
              and
              No chance!
              The string compare is *Mario*Bros.* and *Mario*Bros.*Classic*
              You can edit the ignorelist in line 13 and add Classic, then Classic will be escaped with a star and the search string is *Mario*Bros.* vs *Mario*Bros.*** and this will be a hit!
              PS: Please tag my name, I just searched the forum today and saw an update done to this post. So the bug was very easy to resolve but took some time because I don't checked that post ;)
              EDIT:::
              Reverted the changes.... they don't work escaping /] is a failure
                cyperghost
                Final release
                Fixed error in search level 1 @thelostsoul reported
                • So there is no sed if file is found (I just escaped opening square bracket)
                • Added Region settings mode inspired by @thelostsoul .... This is simply a search with all brackets removed. It will not work very good on arcade games!
                • Added Info text in the beginning (therefore it's a final release because the script explains what it does now ;))
                • All textoutput is hidden now (except if file is not found), so please let the program take it's time, you can enable logging if you edit calls to record() "MESSAGE" "#" the # is a number....
                  • 0 enables text log only
                  • 1 is text log and screen log
                  • 2 is screen log only
                  • last entry is -1, the disables all logging
                  • Guys you will find out
                Examples of it's work
                I used @jamesnj entry for a custom collection: ARCADE COLLECTION and processed with my script
                log output is a 100% conversion!
                Found write with sed: /home/pi/RetroPie/roms/fba/timeplt.zip -- /home/pi/RetroPie/roms/arcade/timeplt.zip
                Found write with sed: /home/pi/RetroPie/roms/fba/atetris.zip -- /home/pi/RetroPie/roms/arcade/atetris.zip
                Found write with sed: /home/pi/RetroPie/roms/fba/qbert.zip -- /home/pi/RetroPie/roms/arcade/qbert.zip
                Found write with sed: /home/pi/RetroPie/roms/fba/jrpacman.zip -- /home/pi/RetroPie/roms/arcade/jrpacman.zip
                Found write with sed: /home/pi/RetroPie/roms/fba/btime.zip -- /home/pi/RetroPie/roms/arcade/btime.zip
                Found write with sed: /home/pi/RetroPie/roms/fba/altbeast.zip -- /home/pi/RetroPie/roms/arcade/altbeast.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/superpac.zip -- /home/pi/RetroPie/roms/arcade/superpac.zip
                Found write with sed: /home/pi/RetroPie/roms/fba/dkong3.zip -- /home/pi/RetroPie/roms/arcade/dkong3.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/pacman.zip -- /home/pi/RetroPie/roms/arcade/pacman.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/astdelux.zip -- /home/pi/RetroPie/roms/arcade/astdelux.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/galaxian.zip -- /home/pi/RetroPie/roms/arcade/galaxian.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/mrdo.zip -- /home/pi/RetroPie/roms/arcade/mrdo.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/mspacman.zip -- /home/pi/RetroPie/roms/arcade/mspacman.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/mpatrol.zip -- /home/pi/RetroPie/roms/arcade/mpatrol.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/digdug.zip -- /home/pi/RetroPie/roms/arcade/digdug.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/kangaroo.zip -- /home/pi/RetroPie/roms/arcade/kangaroo.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/qix.zip -- /home/pi/RetroPie/roms/arcade/qix.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/gravitar.zip -- /home/pi/RetroPie/roms/arcade/gravitar.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/junglek.zip -- /home/pi/RetroPie/roms/arcade/junglek.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/ddragon.zip -- /home/pi/RetroPie/roms/arcade/ddragon.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/spyhunt2.zip -- /home/pi/RetroPie/roms/arcade/spyhunt2.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/ladybug.zip -- /home/pi/RetroPie/roms/arcade/ladybug.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/paperboy.zip -- /home/pi/RetroPie/roms/arcade/paperboy.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/phoenix.zip -- /home/pi/RetroPie/roms/arcade/phoenix.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/sinistar.zip -- /home/pi/RetroPie/roms/arcade/sinistar.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/asteroid.zip -- /home/pi/RetroPie/roms/arcade/asteroid.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/spacedx.zip -- /home/pi/RetroPie/roms/arcade/spacedx.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/defender.zip -- /home/pi/RetroPie/roms/arcade/defender.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/robotron.zip -- /home/pi/RetroPie/roms/arcade/robotron.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/frogger.zip -- /home/pi/RetroPie/roms/arcade/frogger.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/joust.zip -- /home/pi/RetroPie/roms/arcade/joust.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/joust2.zip -- /home/pi/RetroPie/roms/arcade/joust2.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/congo.zip -- /home/pi/RetroPie/roms/arcade/congo.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/dkong.zip -- /home/pi/RetroPie/roms/arcade/dkong.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/dkongjr.zip -- /home/pi/RetroPie/roms/arcade/dkongjr.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/galaga3.zip -- /home/pi/RetroPie/roms/arcade/galaga3.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/galaga.zip -- /home/pi/RetroPie/roms/arcade/galaga.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/gorf.zip -- /home/pi/RetroPie/roms/arcade/gorf.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/invaders.zip -- /home/pi/RetroPie/roms/arcade/invaders.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/vanguard.zip -- /home/pi/RetroPie/roms/arcade/vanguard.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/xevious.zip -- /home/pi/RetroPie/roms/arcade/xevious.zip
                Found write with sed: /home/pi/RetroPie/roms/mame-libretro/zaxxon.zip -- /home/pi/RetroPie/roms/arcade/zaxxon.zip
                thelostsoulT 1 Reply Last reply Reply Quote 1
                • thelostsoulT
                  @cyperghost Thank you for the update. I am currently rebuilding all of my collections. This may take some time. I will test your script someday later and report then.
                    @thelostsoul I used the scrip for your genesis custom collection....
                    2 files are missing....
                    1. Sonic Blast .... This file is not in my collection, so impossible to find
                    2. DECapAttack ... That's an error in writing, so no chance to discover
                    oUTPUT OF LOG
                    https://pastebin.com/9L9D3iU6
