    HDMI to VGA Adaptor Produces no Audio
    23 Posts 15 Posters 15.2k Views
    • XD3lX
      XD3l
      Without this "hdmi_drive=2" added to the config text, NOTHING comes out.
      With it added to config.txt, I hear the speakers pop when I enter and exit an emulator, but that's it.
      • RionR
        Rion
        VGA only send video signals not audio.
        I think you have to find a HDMI to VGA adapter with audio out.
        Edit. Sorry did not see the line out on the picture before I replied..
        FBNeo rom filtering
        Mame2003 Arcade Bezels
        Fba Arcade Bezels
        Fba NeoGeo Bezels
          Twitch0815
          http://celso.io/2012/12/17/connecting-a-raspberry-pi-to-an-old-15khz-arcade-monitor.html
          Check that link out has some usefull information about sound settings and vga
          • XD3lX
            XD3l
            This really should not be complicated.
            FinheadF 1 Reply Last reply Reply Quote 0
            • FinheadF
              Finhead @XD3l
              Try the boot config at the bottom of this page
              XD3lX 1 Reply Last reply Reply Quote 0
              • O
                Oneminde
                That's right. VGA does not have audio. DVI can have audio (depend on version) and SCART have audio. Since I am building a Retropie station, here is what I have selected as solution for my CRT TV.
                XD3lX S G 3 Replies Last reply Reply Quote 0
                • XD3lX
                  XD3l @Finhead
                  @Finhead said in HDMI to VGA Adaptor Produces no Audio:
                  The config file only manages to give me a display that I can not use, so I had to uncomment hdmi_safe=1, though that still leaves me without audio.
                  • XD3lX
                    XD3l @Oneminde
                    @Oneminde said in HDMI to VGA Adaptor Produces no Audio:
                    I don't understand why this will not work. As far as the Pi is concerned, it is outputting to HDMI, audio and all. So this adapter should just do it's job and send the video signal to VGA, and the audio to AUDIO.
                    What I need to do is go VGA out so I can clone the display to two monitors.
                      misslehead3 @XD3l
                      @XD3l What we are doing is using a HDMI to VGA adapter for video and then we are just running the 3.5mm Audio Cable directly from the pi into our monitor. Is there a reason you cant do this.
                      • senkunS
                        senkun
                        @misslehead3 The way I see it, it's not that he can't use the 3.5mm jack out, it's just that he has a hdmi to vga adapter with audio out and he's wondering why it just won't work. So.
                        @XD3l There could be an issue with the adapter itself. One reason is that it could be a dud. Did you get the one from adafruit? Anyways, doesn't really matter, they're all clones of one or the other, all made in China. If from ada, try RMA it. You could pick up another and check, if both don't work then it'll be worth digging further.
                        Did you at least try these lines in your config.txt;
                        hdmi_force_hotplug=1
                        hdmi_drive=2 (I know you have this already)
                        config_hdmi_boost=4 (worth a try)
                        hdmi_force_edid_audio=1 (worth a try)
                          space invader @Oneminde
                          Oneminde, UMSA Scart adaptor says:
                          Converts 15Khz RGBHV via a DSUB HD 15pin to 15Khz RGBS SCART signal
                          So, gertVGA outputs 15khz signal??
                          • XD3lX
                            XD3l @space invader
                            @space-invader Too pricey, I'll just use a micro pc as a sub. The pie
                            shouldn't know it's not using HDMI anyhow.
                              a145
                              This post is deleted!
                                a145
                                  g5k @Oneminde
                                  @Oneminde has this worked out ok for you? I've got an umsa on its way.
                                  In answer to another question raised in the thread about the 15khz h/v signal the umsa is expecting. The HDMI to VGA adaptors can pass 240p from the pi so should be okay. Some adaptors do this some don't.
                                  I guess I'll know for sure soon, keen to hear how it has worked out. It's a shame there hasn't been a one step HDMI to RGB Scart adaptor made when I started looking around just assumed there would be but they only seem to exist with a composite Scart conversion.
                                  Also wondering how well retropie adapts when you change the resolution to 240p. This post seems looks promising.
                                  https://m.reddit.com/r/RetroPie/comments/49wkr9/240p_rgbs_guide_rgb_composite_sync/
                                    asgalvan @senkun
                                    @senkun said in HDMI to VGA Adaptor Produces no Audio:
                                    I had this issue that the OP had as well. I added:
                                    hdmi_drive=2 (which I had already)
                                    and now my HDMI to VGA/Sound adapter is now outputting sound in RetroPie with my Zero. Thank you.
                                    XD3lX 1 Reply Last reply Reply Quote 1
                                      edmaul69 @XD3l
                                      @XD3l i can confirm that what @asgalvan posted fixes this on this vga adapter.
                                        javadood
                                        I had the same problem and finally got it working by reading this: https://www.riscosopen.org/forum/forums/11/topics/1865
                                        ssh into your pi
                                        then do this: amixer cset numid=3 1
                                        • XD3lX
                                          XD3l @asgalvan
                                          @asgalvan said in HDMI to VGA Adaptor Produces no Audio:
                                          Bingo, and thank you!!!
                                            ayskura
                                            Fantastic News, where do I find the config.txt to add those lines? How do I change it? can I do it from Retropie as my raspberry pi has not internet connections? thank you
