    Help PS3 controller
    11 Posts 3 Posters 4.3k Views
    • V
      vincedj
      hello, what is the mode to set start+select to exit all the emulator on ps3 controller ?
      which is the file to edit and what i have to change.
      Thanks in advance
      • V
        vincedj
        any ideas ?
        I've just try to edit retroarch.cfg after jstest but not working
          Douggernaut
          Check in /opt/retropie/configs/all/retroarch-joypads/ for a config file for your controller.
          Look for input_enable_hotkey_btn (same as select) input_exit_emulator_btn (same as start) in there.
          • V
            vincedj
            my select button is 0 and start is 3 , I just add these 2 line to my joy config in /opt/retropie/configs/all/retroarch-joypads/
            but still not work.
              Douggernaut
              Please post the full contents of the file you edited.
              • V
                vincedj
                input_device = "PLAYSTATION(R)3 Controller"
                input_driver = "udev"
                input_r_y_plus_axis = "+3"
                input_l3_btn = "1"
                input_r_x_minus_axis = "-2"
                input_r_btn = "9"
                input_save_state_btn = "9"
                input_l2_btn = "10"
                input_start_btn = "3"
                input_exit_emulator_btn = "3"
                input_l_y_minus_axis = "-1"
                input_l_btn = "8"
                input_load_state_btn = "8"
                input_up_btn = "4"
                input_r_y_minus_axis = "-3"
                input_a_btn = "13"
                input_b_btn = "14"
                input_reset_btn = "14"
                input_down_btn = "6"
                input_r2_btn = "11"
                input_l_x_plus_axis = "+0"
                input_l_y_plus_axis = "+1"
                input_r3_btn = "2"
                input_right_btn = "5"
                input_state_slot_increase_btn = "5"
                input_x_btn = "12"
                input_menu_toggle_btn = "12"
                input_select_btn = "0"
                input_enable_hotkey_btn = "0"
                input_l_x_minus_axis = "-0"
                input_y_btn = "15"
                input_left_btn = "7"
                input_state_slot_decrease_btn = "7"
                input_r_x_plus_axis = "+2"
                • V
                  vincedj
                  Skeleton config file for RetroArch
                  Save all save files (.srm) to this directory. This includes related files like .bsv, .rtc, .psrm, etc ...
                  This will be overridden by explicit command line options.
                  savefile_directory =
                  Save all save states (
                  .state) to this directory.
                  savestate_directory =
                  If set to a directory, Content which is temporarily extracted
                  will be extracted to this directory.
                  cache_directory = "/tmp/retroarch"
                  Save all input remapping files to this directory.
                  input_remapping_directory =
                  Save all playlist files to this directory.
                  playlist_directory =
                  If set to a directory, the content history playlist will be saved
                  to this directory.
                  content_history_dir =
                  Automatically saves a savestate at the end of RetroArch's lifetime.
                  The path is $SRAM_PATH.auto.
                  RetroArch will automatically load any savestate with this path on startup if savestate_auto_load is set.
                  savestate_auto_save = false
                  savestate_auto_load = true
                  Load libretro from a dynamic location for dynamically built RetroArch.
                  This option is mandatory.
                  Path to a libretro implementation.
                  libretro_path = "/path/to/libretro.so"
                  A directory for where to search for libretro core implementations.
                  libretro_directory =
                  A directory for where to search for libretro core information.
                  libretro_info_path =
                  Sets log level for libretro cores (GET_LOG_INTERFACE).
                  If a log level issued by a libretro core is below libretro_log_level, it is ignored.
                  DEBUG logs are always ignored unless verbose mode is activated (--verbose).
                  DEBUG = 0, INFO = 1, WARN = 2, ERROR = 3.
                  libretro_log_level = 0
                  Enable or disable verbosity level of frontend.
                  log_verbosity = false
                  If this option is enabled, every content file loaded in RetroArch will be
                  automatically added to a history list.
                  history_list_enable = true
                  Enable or disable RetroArch performance counters
                  perfcnt_enable = false
                  Path to core options config file.
                  This config file is used to expose core-specific options.
                  It will be written to by RetroArch.
                  A default path will be assigned if not set.
                  core_options_path = "/opt/retropie/configs/all/retroarch-core-options.cfg"
                  Path to content load history file.
                  RetroArch keeps track of all content loaded in the menu and from CLI directly for convenient quick loading.
                  content_history_path =
                  Number of entries that will be kept in content history file.
                  content_history_size = 100
                  Sets the "system" directory.
                  Implementations can query for this directory to load BIOSes, system-specific configs, etc.
                  system_directory = "/home/pi/RetroPie/BIOS"
                  Sets start directory for menu content browser.
                  rgui_browser_directory =
                  Content directory. Interacts with RETRO_ENVIRONMENT_GET_CONTENT_DIRECTORY.
                  Usually set by developers who bundle libretro/RetroArch apps to point to assets.
                  content_directory =
                  Assets directory. This location is queried by default when menu interfaces try to look for
                  loadable assets, etc.
                  assets_directory = "/opt/retropie/emulators/retroarch/assets"
                  Dynamic wallpapers directory. The place to store the wallpapers dynamically
                  loaded by the menu depending on context.
                  dynamic_wallpapers_directory =
                  Thumbnails directory. To store thumbnail PNG files.
                  thumbnails_directory =
                  Sets start directory for menu config browser.
                  rgui_config_directory =
                  Show startup screen in menu.
                  Is automatically set to false when seen for the first time.
                  This is only updated in config if config_save_on_exit is set to true, however.
                  rgui_show_start_screen = true
                  Flushes config to disk on exit. Useful for menu as settings can be modified.
                  Overwrites the config. #include's and comments are not preserved.
                  config_save_on_exit = "false"
                  Load up a specific config file based on the core being used.
                  core_specific_config = false
                  Video
                  Video driver to use. "gl", "xvideo", "sdl"
                  video_driver = "gl"
                  Which OpenGL context implementation to use.
                  Possible ones for desktop are: glx, x-egl, kms-egl, sdl-gl, wgl.
                  By default, tries to use first suitable driver.
                  video_context_driver =
                  Windowed x resolution scale and y resolution scale
                  (Real x res: base_size * xscale * aspect_ratio, real y res: base_size * yscale)
                  video_scale = 3.0
                  Fullscreen resolution. Resolution of 0 uses the resolution of the desktop.
                  video_fullscreen_x = 0
                  video_fullscreen_y = 0
                  Start in fullscreen. Can be changed at runtime.
                  video_fullscreen = false
                  If fullscreen, prefer using a windowed fullscreen mode.
                  video_windowed_fullscreen = true
                  Which monitor to prefer. 0 (default) means no particular monitor is preferred, 1 and up (1 being first monitor),
                  suggests RetroArch to use that particular monitor.
                  video_monitor_index = 0
                  Forcibly disable composition. Only works in Windows Vista/7 for now.
                  video_disable_composition = false
                  Video vsync.
                  video_vsync = true
                  Forcibly disable sRGB FBO support. Some Intel OpenGL drivers on Windows
                  have video problems with sRGB FBO support enabled.
                  video_force_srgb_disable = false
                  Attempts to hard-synchronize CPU and GPU. Can reduce latency at cost of performance.
                  video_hard_sync = false
                  Sets how many frames CPU can run ahead of GPU when using video_hard_sync.
                  Maximum is 3.
                  video_hard_sync_frames = 0
                  Sets how many milliseconds to delay after VSync before running the core.
                  Can reduce latency at cost of higher risk of stuttering.
                  Maximum is 15.
                  video_frame_delay = 0
                  Inserts a black frame inbetween frames.
                  Useful for 120 Hz monitors who want to play 60 Hz material with eliminated ghosting.
                  video_refresh_rate should still be configured as if it is a 60 Hz monitor (divide refresh rate by 2).
                  video_black_frame_insertion = false
                  Use threaded video driver. Using this might improve performance at possible cost of latency and more video stuttering.
                  video_threaded = "true"
                  Use a shared context for HW rendered libretro cores.
                  Avoids having to assume HW state changes inbetween frames.
                  video_shared_context = false
                  Smoothens picture with bilinear filtering. Should be disabled if using pixel shaders.
                  video_smooth = "false"
                  Forces rendering area to stay equal to content aspect ratio or as defined in video_aspect_ratio.
                  video_force_aspect = true
                  Only scales video in integer steps.
                  The base size depends on system-reported geometry and aspect ratio.
                  If video_force_aspect is not set, X/Y will be integer scaled independently.
                  video_scale_integer = false
                  A floating point value for video aspect ratio (width / height).
                  If this is not set, aspect ratio is assumed to be automatic.
                  Behavior then is defined by video_aspect_ratio_auto.
                  video_aspect_ratio =
                  If this is true and video_aspect_ratio is not set,
                  aspect ratio is decided by libretro implementation.
                  If this is false, 1:1 PAR will always be assumed if video_aspect_ratio is not set.
                  video_aspect_ratio_auto = "true"
                  Forces cropping of overscanned frames.
                  Exact behavior of this option is implementation specific.
                  video_crop_overscan = true
                  Path to shader. Shader can be either Cg, CGP (Cg preset) or GLSL, GLSLP (GLSL preset)
                  video_shader = "/path/to/shader.{cg,cgp,glsl,glslp}"
                  Load video_shader on startup.
                  Other shaders can still be loaded later in runtime.
                  video_shader_enable = false
                  Defines a directory where shaders (Cg, CGP, GLSL) are kept for easy access.
                  video_shader_dir = "/opt/retropie/emulators/retroarch/shader/"
                  CPU-based video filter. Path to a dynamic library.
                  video_filter =
                  Defines a directory where CPU-based video filters are kept.
                  video_filter_dir =
                  Path to a font used for rendering messages. This path must be defined to enable fonts.
                  Do note that the full path of the font is necessary!
                  video_font_path =
                  Size of the font rendered.
                  video_font_size = "12"
                  Enable usage of OSD messages.
                  video_font_enable = true
                  Offset for where messages will be placed on screen. Values are in range 0.0 to 1.0 for both x and y values.
                  [0.0, 0.0] maps to the lower left corner of the screen.
                  video_message_pos_x = 0.05
                  video_message_pos_y = 0.05
                  Color for message. The value is treated as a hexadecimal value.
                  It is a regular RGB hex number, i.e. red is "ff0000".
                  video_message_color = ffffff
                  Video refresh rate of your monitor.
                  Used to calculate a suitable audio input rate.
                  video_refresh_rate = 59.95
                  Allows libretro cores to set rotation modes.
                  Setting this to false will honor, but ignore this request.
                  This is useful for vertically oriented content where one manually rotates the monitor.
                  video_allow_rotate = true
                  Forces a certain rotation of the screen.
                  The rotation is added to rotations which the libretro core sets (see video_allow_rotate).
                  The angle is <value> * 90 degrees counter-clockwise.
                  video_rotation = 0
                  Audio
                  Enable audio.
                  audio_enable = true
                  Mutes audio.
                  audio_mute_enable = false
                  Audio output samplerate.
                  audio_out_rate = 48000
                  Audio resampler backend. Which audio resampler to use.
                  Default will use "sinc".
                  audio_resampler =
                  Audio driver backend. Depending on configuration possible candidates are: alsa, pulse, oss, jack, rsound, roar, openal, sdl, xaudio.
                  audio_driver =
                  Override the default audio device the audio_driver uses. This is driver dependant. E.g. ALSA wants a PCM device, OSS wants a path (e.g. /dev/dsp), Jack wants portnames (e.g. system:playback1,system:playback_2), and so on ...
                  audio_device =
                  Audio DSP plugin that processes audio before it's sent to the driver. Path to a dynamic library.
                  audio_dsp_plugin =
                  Directory where DSP plugins are kept.
                  audio_filter_dir =
                  Will sync (block) on audio. Recommended.
                  audio_sync = true
                  Desired audio latency in milliseconds. Might not be honored if driver can't provide given latency.
                  audio_latency = 64
                  Enable audio rate control.
                  audio_rate_control = true
                  Controls audio rate control delta. Defines how much input rate can be adjusted dynamically.
                  Input rate = in_rate * (1.0 +/- audio_rate_control_delta)
                  audio_rate_control_delta = 0.005
                  Controls maximum audio timing skew. Defines the maximum change in input rate.
                  Input rate = in_rate * (1.0 +/- max_timing_skew)
                  audio_max_timing_skew = 0.05
                  Audio volume. Volume is expressed in dB.
                  0 dB is normal volume. No gain will be applied.
                  Gain can be controlled in runtime with input_volume_up/input_volume_down.
                  audio_volume = 0.0
                  Overlay
                  Defines a directory where overlays are kept for easy access.
                  overlay_directory = "/opt/retropie/emulators/retroarch/overlays"
                  Enable or disable the current overlay.
                  input_overlay_enable = true
                  Hide the current overlay from appearing in menu screens.
                  input_overlay_hide_in_menu = true
                  Path to input overlay
                  input_overlay =
                  Overlay opacity
                  input_overlay_opacity = 1.0
                  Overlay scale
                  input_overlay_scale = 1.0
                  OSK (Onscreen Keyboard) Overlay
                  osk_overlay_directory =
                  Enable OSK overlay.
                  input_osk_overlay_enable = true
                  Path to OSK overlay
                  input_osk_overlay =
                  OSK Overlay opacity
                  input_osk_overlay_opacity = 1.0
                  OSK Overlay scale
                  input_osk_overlay_scale = 1.0
                  Input
                  Input driver. Depending on video driver, it might force a different input driver.
                  input_driver = sdl
                  Input device driver. (Valid: linuxraw, sdl, dinput)
                  input_joypad_driver = "udev"
                  Path to input remapping file.
                  input_remapping_path =
                  If enabled, overrides the input binds with the remapped binds set for the current core.
                  input_remap_binds_enable = true
                  Maximum amount of users supported by RetroArch.
                  input_max_users = 16
                  Keyboard layout for input driver if applicable (udev/evdev for now).
                  Syntax is either just layout (e.g. "no"), or a layout and variant separated with colon ("no:nodeadkeys").
                  input_keyboard_layout =
                  Defines axis threshold. Possible values are [0.0, 1.0]
                  input_axis_threshold = 0.5
                  Enable input auto-detection. Will attempt to autoconfigure
                  joypads, Plug-and-Play style.
                  input_autodetect_enable = "true"
                  Show the input descriptors set by the core instead of the
                  default ones.
                  input_descriptor_label_show = true
                  Hide input descriptors that were not set by the core.
                  input_descriptor_hide_unbound = false
                  Influence how input polling is done inside RetroArch.
                  0 : Early - Input polling is performed before call to retro_run.
                  1 : Normal - Input polling is performend when retro_input_poll is
                  requested.
                  2 : Late - Input polling is performed on first call to retro_input_state
                  per frame
                  Setting it to 0 or 2 can result in less latency depending on
                  your configuration.
                  When netplay is enabled, the default polling behavior (1) will
                  be used regardless of the value set here.
                  input_poll_type_behavior = 1
                  Directory for joypad autoconfigs.
                  If a joypad is plugged in, that joypad will be autoconfigured if a config file
                  corresponding to that joypad is present in joypad_autoconfig_dir.
                  Input binds which are made explicit (input_playerN_*_btn/axis) will take priority over autoconfigs.
                  Autoconfigs can be created with retroarch-joyconfig, manually, or with a frontend.
                  Requires input_autodetect_enable to be enabled.
                  joypad_autoconfig_dir = "/opt/retropie/configs/all/retroarch-joypads/"
                  Sets which libretro device is used for a user.
                  Devices are indentified with a number.
                  This is normally saved by the menu.
                  Device IDs are found in libretro.h.
                  These settings are overridden by explicit command-line arguments which refer to input devices.
                  None: 0
                  Joypad (RetroPad): 1
                  Mouse: 2
                  Keyboard: 3
                  Generic Lightgun: 4
                  Joypad w/ Analog (RetroPad + Analog sticks): 5
                  Multitap (SNES specific): 257
                  Super Scope (SNES specific): 260
                  Justifier (SNES specific): 516
                  Justifiers (SNES specific): 772
                  input_libretro_device_p1 =
                  input_libretro_device_p2 =
                  input_libretro_device_p3 =
                  input_libretro_device_p4 =
                  input_libretro_device_p5 =
                  input_libretro_device_p6 =
                  input_libretro_device_p7 =
                  input_libretro_device_p8 =
                  Keyboard input. Will recognize letters ("a" to "z") and the following special keys (where "kp_"
                  is for keypad keys):
                  left, right, up, down, enter, kp_enter, tab, insert, del, end, home,
                  rshift, shift, ctrl, alt, space, escape, add, subtract, kp_plus, kp_minus,
                  f1, f2, f3, f4, f5, f6, f7, f8, f9, f10, f11, f12,
                  num0, num1, num2, num3, num4, num5, num6, num7, num8, num9, pageup, pagedown,
                  keypad0, keypad1, keypad2, keypad3, keypad4, keypad5, keypad6, keypad7, keypad8, keypad9,
                  period, capslock, numlock, backspace, multiply, divide, print_screen, scroll_lock,
                  tilde, backquote, pause, quote, comma, minus, slash, semicolon, equals, leftbracket,
                  backslash, rightbracket, kp_period, kp_equals, rctrl, ralt
                  Keyboard input, Joypad and Joyaxis will all obey the "nul" bind, which disables the bind completely,
                  rather than relying on a default.
                  input_player1_a = "x"
                  input_player1_b = "z"
                  input_player1_y = "a"
                  input_player1_x = "s"
                  input_player1_start = "enter"
                  input_player1_select = "rshift"
                  input_player1_l = "q"
                  input_player1_r = "w"
                  input_player1_left = "left"
                  input_player1_right = "right"
                  input_player1_up = "up"
                  input_player1_down = "down"
                  input_player1_l2 =
                  input_player1_r2 =
                  input_player1_l3 =
                  input_player1_r3 =
                  Two analog sticks (DualShock-esque).
                  Bound as usual, however, if a real analog axis is bound,
                  it can be read as a true analog.
                  Positive X axis is right, Positive Y axis is down.
                  input_player1_l_x_plus =
                  input_player1_l_x_minus =
                  input_player1_l_y_plus =
                  input_player1_l_y_minus =
                  input_player1_r_x_plus =
                  input_player1_r_x_minus =
                  input_player1_r_y_plus =
                  input_player1_r_y_minus =
                  If desired, it is possible to override which joypads are being used for user 1 through 8.
                  First joypad available is 0.
                  input_player1_joypad_index = 0
                  input_player2_joypad_index = 1
                  input_player3_joypad_index = 2
                  input_player4_joypad_index = 3
                  input_player5_joypad_index = 4
                  input_player6_joypad_index = 5
                  input_player7_joypad_index = 6
                  input_player8_joypad_index = 7
                  Input device buttons.
                  Figure these out by using RetroArch-Phoenix or retroarch-joyconfig.
                  You can use joypad hats with hnxx, where n is the hat, and xx is a string representing direction.
                  E.g. "h0up"
                  input_player1_a_btn =
                  input_player1_b_btn =
                  input_player1_y_btn =
                  input_player1_x_btn =
                  input_player1_start_btn =
                  input_player1_select_btn =
                  input_player1_l_btn =
                  input_player1_r_btn =
                  input_player1_left_btn =
                  input_player1_right_btn =
                  input_player1_up_btn =
                  input_player1_down_btn =
                  input_player1_l2_btn =
                  input_player1_r2_btn =
                  input_player1_l3_btn =
                  input_player1_r3_btn =
                  Menu buttons.
                  menu_ok_btn =
                  menu_cancel_btn =
                  menu_search_btn =
                  menu_info_btn =
                  menu_default_btn =
                  menu_scroll_down_btn =
                  menu_scroll_up_btn =
                  Axis for RetroArch D-Pad.
                  Needs to be either '+' or '-' in the first character signaling either positive or negative direction of the axis, then the axis number.
                  Do note that every other input option has the corresponding _btn and _axis binds as well; they are omitted here for clarity.
                  input_player1_left_axis =
                  input_player1_right_axis =
                  input_player1_up_axis =
                  input_player1_down_axis =
                  Holding the turbo while pressing another button will let the button enter a turbo mode
                  where the button state is modulated with a periodic signal.
                  The modulation stops when the button itself (not turbo button) is released.
                  input_player1_turbo =
                  Describes the period and how long of that period a turbo-enabled button should behave.
                  Numbers are described in frames.
                  input_turbo_period = 6
                  input_turbo_duty_cycle = 3
                  This goes all the way to user 8 (player2, player3, etc), but omitted for clarity.
                  All input binds have corresponding binds for keyboard (none), joykeys (_btn) and joyaxes (_axis) as well.
                  Toggles fullscreen.
                  input_toggle_fullscreen = f
                  Saves state.
                  input_save_state = f2
                  Loads state.
                  input_load_state = f4
                  State slots. With slot set to 0, save state name is *.state (or whatever defined on commandline).
                  When slot is != 0, path will be $path%d, where %d is slot number.
                  input_state_slot_increase = f7
                  input_state_slot_decrease = f6
                  Toggles between fast-forwarding and normal speed.
                  input_toggle_fast_forward = space
                  Hold for fast-forward. Releasing button disables fast-forward.
                  input_hold_fast_forward = l
                  Key to exit RetroArch cleanly.
                  Killing it in any hard way (SIGKILL, etc) will terminate RetroArch without saving RAM, etc.
                  On Unix-likes, SIGINT/SIGTERM allows a clean deinitialization.
                  #input_exit_emulator = "escape"
                  input_exit_emulator = "3"
                  Applies next and previous shader in directory.
                  input_shader_next = "m"
                  input_shader_prev = "n"
                  Hold button down to rewind. Rewinding must be enabled.
                  input_rewind = "r"
                  Toggle between recording and not.
                  input_movie_record_toggle = o
                  Toggle between paused and non-paused state
                  input_pause_toggle = p
                  Frame advance when content is paused
                  input_frame_advance = k
                  Reset the content.
                  input_reset = h
                  Cheats.
                  input_cheat_index_plus = y
                  input_cheat_index_minus = t
                  input_cheat_toggle = u
                  Mute/unmute audio
                  input_audio_mute = f9
                  Take screenshot
                  input_screenshot = f8
                  Netplay flip users.
                  input_netplay_flip_players = i
                  Hold for slowmotion.
                  input_slowmotion = e
                  Enable other hotkeys.
                  If this hotkey is bound to either keyboard, joybutton or joyaxis,
                  all other hotkeys will be disabled unless this hotkey is also held at the same time.
                  This is useful for RETRO_KEYBOARD centric implementations
                  which query a large area of the keyboard, where it is not desirable
                  that hotkeys get in the way.
                  Alternatively, all hotkeys for keyboard could be disabled by the user.
                  Increases audio volume.
                  input_volume_up = kp_plus
                  Decreases audio volume.
                  input_volume_down = kp_minus
                  Toggles to next overlay. Wraps around.
                  input_overlay_next =
                  Toggles eject for disks. Used for multiple-disk content.
                  input_disk_eject_toggle =
                  Cycles through disk images. Use after ejecting.
                  Complete by toggling eject again.
                  input_disk_next =
                  Toggles menu.
                  input_menu_toggle = f1
                  RetroPad button combination to toggle menu
                  0 = none, 1 = L + R + Y + D-Pad Down, 2 = L3 + R3
                  input_menu_toggle_gamepad_combo = 0
                  Toggles mouse grab. When mouse is grabbed, RetroArch hides the mouse,
                  and keeps the mouse pointer inside the window to allow relative mouse input
                  to work better.
                  input_grab_mouse_toggle = f11
                  Menu
                  Menu driver to use. "rgui", "lakka", etc.
                  menu_driver = "rgui"
                  If enabled, the libretro core will keep running in the background when we
                  are in the menu.
                  menu_pause_libretro = false
                  Enable mouse input inside the menu.
                  menu_mouse_enable = false
                  Enable touch input inside the menu.
                  menu_pointer_enable = false
                  Shows current date and/or time inside menu.
                  menu_timedate_enable = true
                  Shows current core inside menu.
                  menu_core_enable = true
                  Path to a .png image to set as menu wallpaper.
                  menu_wallpaper =
                  Dynamically load a new wallpaper depending on context.
                  menu_dynamic_wallpaper_enable = false
                  Type of thumbnail to display. 0 = none, 1 = snaps, 2 = titles, 3 = boxarts
                  menu_thumbnails = 0
                  Wrap-around toe beginning and/or end if boundary of list reached horizontally
                  menu_navigation_wraparound_horizontal_enable = false
                  Wrap-around to beginning and/or end if boundary of list reached vertically
                  menu_navigation_wraparound_vertical_enable = false
                  Filter files being show in 'Load Content' by supported extensions
                  menu_navigation_browser_filter_supported_extensions_enable = true
                  Collapse subgroup settings into main group to create one big listing of settings
                  per category.
                  menu_collapse_subgroups_enable = false
                  UI
                  Suspends the screensaver if set to true. Is a hint that does not necessarily have to be honored
                  by video driver.
                  suspend_screensaver_enable = true
                  Start UI companion driver's interface on boot (if available).
                  ui_companion_start_on_boot = true
                  Camera
                  Override the default camera device the camera driver uses. This is driver dependant.
                  camera_device =
                  Override the default privacy permission for cores that want to access camera services. Is "false" by default.
                  camera_allow = false
                  Location
                  Override the default privacy permission for cores that want to access location services. Is "false" by default.
                  location_allow = false
                  Core Updater
                  URL to core update directory on buildbot.
                  core_updater_buildbot_url = "http://buildbot.libretro.com"
                  URL to assets update directory on buildbot.
                  core_updater_buildbot_assets_url = "http://buildbot.libretro.com/assets/"
                  Automatically extract archives that the cores are contained in to the libretro cores directory.
                  core_updater_auto_extract_archive = true
                  Network
                  When being client over netplay, use keybinds for user 1.
                  netplay_client_swap_input = false
                  The username of the person running RetroArch. This will be used for playing online, for instance.
                  netplay_nickname =
                  The amount of delay frames to use for netplay. Increasing this value will increase
                  performance, but introduce more latency.
                  netplay_delay_frames = 0
                  Netplay mode for the current user.
                  false is Server, true is Client.
                  netplay_mode = false
                  Enable or disable spectator mode for the user during netplay.
                  netplay_spectator_mode_enable = false
                  The IP Address of the host to connect to.
                  netplay_ip_address =
                  The port of the host IP Address. Can be either a TCP or an UDP port.
                  netplay_ip_port = 55435
                  Misc
                  Enable rewinding. This will take a performance hit when playing, so it is disabled by default.
                  rewind_enable = "false"
                  Rewinding buffer size in megabytes. Bigger rewinding buffer means you can rewind longer.
                  The buffer should be approx. 20MB per minute of buffer time.
                  rewind_buffer_size = "10"
                  Rewind granularity. When rewinding defined number of frames, you can rewind several frames at a time, increasing the rewinding speed.
                  rewind_granularity = "2"
                  Pause gameplay when window focus is lost.
                  pause_nonactive = true
                  Autosaves the non-volatile SRAM at a regular interval. This is disabled by default unless set otherwise.
                  The interval is measured in seconds. A value of 0 disables autosave.
                  autosave_interval =
                  Path to content database directory.
                  content_database_path =
                  Path to cheat database directory.
                  cheat_database_path =
                  Path to XML cheat config, a file which keeps track of which
                  cheat settings are used for individual games.
                  If the file does not exist, it will be created.
                  cheat_settings_path =
                  Directory to dump screenshots to.
                  screenshot_directory =
                  Records video after CPU video filter.
                  video_post_filter_record = false
                  Records output of GPU shaded material if available.
                  video_gpu_record = false
                  Screenshots output of GPU shaded material if available.
                  video_gpu_screenshot = "true"
                  Block SRAM from being overwritten when loading save states.
                  Might potentially lead to buggy games.
                  block_sram_overwrite = false
                  When saving a savestate, save state index is automatically increased before
                  it is saved.
                  Also, when loading content, the index will be set to the highest existing index.
                  There is no upper bound on the index.
                  savestate_auto_index = false
                  Slowmotion ratio. When slowmotion, content will slow down by factor.
                  slowmotion_ratio = 3.0
                  The maximum rate at which content will be run when using fast forward. (E.g. 5.0 for 60 fps content => 300 fps cap).
                  RetroArch will go to sleep to ensure that the maximum rate will not be exceeded.
                  Do not rely on this cap to be perfectly accurate.
                  If this is set at 0, then fastforward ratio is unlimited (no FPS cap)
                  fastforward_ratio = 0.0
                  Enable stdin/network command interface.
                  network_cmd_enable = false
                  network_cmd_port = 55355
                  stdin_cmd_enable = false
                  input_enable_hotkey = "nul"
                  auto_remaps_enable = "true"
                  herb_fargusH V 2 Replies Last reply Reply Quote 0
                  • herb_fargusH
                    herb_fargus administrators @vincedj
                    @vincedj https://retropie.org.uk/forum/topic/3/read-this-first
                    Use pastebin for large logs and any code that is posted please format accordingly.
                    • V
                      vincedj
                      sorry Herb
                      forgive me
                        Douggernaut @vincedj
                        @vincedj Could you edit your comment to add formatting?
                        • V
                          vincedj @vincedj
                          This post is deleted!
