    Nespicase + problem to feed pi 3
    nespicase+pi 3retropie 4.4
    11 Posts 7 Posters 1.5k Views
      A Former User
      Hello everyone
      My problem is that my pi 3 does not turn on when it plugs into the gpio .
      Watch my video to understand
      https://sendvid.com/9p007019
      Here is a 2nd video that shows you that my raspberry works well .
      https://sendvid.com/iqdocdu0
      my power supply
      my power supply
      I hope you can help me because I'm lost.
      thank you in advance
      • quicksilverQ
        quicksilver
        Iooks defective, I would send it back for a replacement
          A Former User
          You believe that the nespi box and dead?
          jonnykeshJ BuZzB 3 Replies Last reply Reply Quote 0
          • jonnykeshJ
            jonnykesh @A Former User
            @bizous Well, yes. The Pi works when not connected via the NESPI case boards. Assuming you have wired everything correctly then the only logical explanation is a problem with the case.
            Return it and get a replacement.
              edmaul69
              A pi inside the nespi cases require more power than the pi by itself. It might be the cheap power supply that is the issue. It might not really be anywhere near 3000ma.
                edmaul69
                And you want a power supply that is at least 5.1v output when using the nespi case.
                  BuZz administrators @A Former User
                  @bizous Emails to your forum email address are bouncing (free.fr reporting all as spam). Nothing I can do about it my end (server is not blacklisted or anything), so it might be worth using another email account, or unsubscribing from category email notifications.
                  • KN4THXK
                    KN4THX
                    Honestly since the Nespi doesn't light up it is probably defective. The case is powered before the Pi so the red LED should be lit. It's possible the connector on the power button is not making contact but I'd just send it back unless you like soldering (and yes I say sole-der :)).
                    "If you're gonna play the Game Boy, You gotta learn to play it right" - https://www.youtube.com/watch?v=FYLGl92ETNQ
                      edmaul69 @KN4THX
                      @thedatacereal the light doesn’t always come on right away on the nespi case+. It is perfectly normal.
                      • jamesnjJ
                        jamesnj
                        I've found that the power port on the nespi cases are a bit temperamental. On all the cases I've purchased, I observed that sometimes the power connection is no so secure, like the gap created between the case plastic and the port is just a hair too much. All my cases have worked, but I still feel like a bit of grinding with a Dremel around the power port area might help ... I just haven't been brave enough to try that yet. Sometimes I simply need to pull the power plug out and make sure it is firmly pressed in and square/tight against the case plastic.
                        Also, a very strong power supply helps. I would suggest one of the newer 5v/3a models. I had a typical 2.5a unit connected to one of mine, and the power supply ended up frying. Annoying power indicator flashed all the time and I suspect the constant heavy draw just caused it to go bad.
                          @bizous The email address you registered on the forum no longer exists - please update it or I will have to remove your account (as you have subscribed to some categories and emails are bouncing).
