    transfer roms though lan cat5 cable?
    cat5lanromstransfer
    23 Posts 8 Posters 8.0k Views
      edmaul69 @edmaul69
      @edmaul69 transferring roms through ethernet is 1000’s of times faster. Any wireless connection is far too slow
        steptoe
        I first used Putty, but far too slow due to encryption. I then tried FileZilla, much much faster, but still use Putty to access the PI and run or edit some thinga via Putty through a console on the Windows desktop. N ever used wireless, far too slow and problems with connections as you've found out
        https://www.raspberrypi.org/documentation/remote-access/ssh/windows.md
        Transferring ROMs via FileZilla is about as fast as you will get over an thernet cable, which is what I use but I use cat6 cables
        https://www.dexterindustries.com/howto/how-to-transfer-files-to-your-raspberry-pi-from-a-pc-computer/
          Davey92
          All i did on my retropie was enabled ssh and 1 wire turned on network discovery on my pc and it worked! With a cat 6 ethernet cable
