    Audio not working after messing with shaders
    audio problemsaudio issues
    7 Posts 2 Posters 915 Views
    • RetroJag1R
      RetroJag1
      I was messing around with shaders overlays to try and make my games look nicer. My audio cut out completely after i was messing round with shaders on the psx emulator and i have searched on the internet for hours but still cant find anything that helps!
        mitu Global Moderator @RetroJag1
        @retrojag1 Shaders modify the video image, can't see how that would affect the sound, but.. Please give more details about your system - https://retropie.org.uk/forum/topic/3/read-this-first.
        RetroJag1R 2 Replies Last reply Reply Quote 0
        • RetroJag1R
          RetroJag1 @mitu
          @mitu I don't know if it was the shaders but it did stop working as i was trying to add shaders ont my ps1 emulator. I don't know if i have deleted any important files or anything it just doesn't work. :'(
          • RetroJag1R
            RetroJag1 @mitu
            @mitu btw i have a raspberry pi 3b running on the official retropie image and powered by the original raspberrypi power supply. I have only got MAME NES PSX MAME LIBRETRO AND ATARI emulators
              So, did you copy or deleted some files - how did you add the shaders ? Or are you talking about overlays ?
              RetroJag1R 1 Reply Last reply Reply Quote 0
              • RetroJag1R
                RetroJag1 @mitu
                @mitu i was kinda adding the shader and overlays at the same time and after i exited retroarch the audio stopped working
                • RetroJag1R
                  RetroJag1 @RetroJag1
                  Dont worry i fixed it turnes out i just had o switch the audio from auto to the audio output in the audio menu.
