    controller problems
    nespi case
    7 Posts 4 Posters 1.4k Views
      thisguy
      I just got nespi case and the controllers work fine in the menu section but as soon as I enter any game they dont work at all
        mediamogul Global Moderator @thisguy
        @thisguy
        You'll need to post more information about your setup. The required information can be found at https://retropie.org.uk/forum/topic/3/read-this-first
        • W
          wihaedud
          Which emulators are you trying to use? Are you using wired or bluetooth controller. Did you try to unplug an replug your controller ingame?
            thisguy
            ok the box says nespi case × 1, compatible with raspberry pi 3, 2 and b+
            the controllers are wireless ps3 imitations that use batteries
              thisguy @wihaedud
              they are wireless ps3 imitations with batteries, I believe they are using bluetooth yes. I tried unplugging in the game but nothing, I just dont get how they work perfectly in the menu screen but not in games. the system comes with a keyboard pad that does work in the menu screen and in game, obviously you cant play very much with the keyboard pad but it does work
                @thisguy
                As noted above, we really need more information to help. That information is detailed at https://retropie.org.uk/forum/topic/3/read-this-first
                  paulowens001
                  I am guessing this is similar to the problem I have an trying to figure out. The controller works in EmuStation but any game that uses Retro Arch it doesn't. I have an Xbox usb controller and the solution is to unplug an replug. The Commodore 64 emulator for example doesn't have the issue.
