    TriggerHappy Daemon (THD) doesn't work on my Pi running Retropie ! Help
    retropietriggerhappydaemonhelpbug
    32 Posts 4 Posters 9.6k Views
      Djon
      Hi, i think the title is pretty clear :)
      I followed multiple tutorial to set up triggerhappy but nothing happen...
      I mostly use this one : https://timee1994.weebly.com/nintimdo-rp-instructions.html ( go directly to the triggerhappy section).
      So instaled triggerhappy : sudo apt-get install triggerhappy
      When i do and press the key i want to use : thd --dump /dev/input/event*
      I got : "EV_KEY BTN_BASE6 1 /dev/input/event4 "
      "# BTN_BASE6 1 command "
      "EV_KEY BTN_BASE6 0 /dev/input/event4 "
      "# BTN_BASE6 0 command"
      Finally i did : pi@retropie:~ $ sudo nano /etc/triggerhappy/triggers.d/testb.conf
      and write inside : BTN_BASE6 1 sudo chmod 777 /sys/class/backlight/rpi_backlight/brightness && echo 25 > /sys/class/backlight/rpi_backlight/brightness
      ( the script sudo chmod 777... is useful to control the brightness of the Pi screen, and it works great when i type it in the terminal via SSH)
      And restart triggerhappy : sudo service triggerhappy restart
      I guess i do something wrong... please help me ! Thanks !
        You don't need to use sudo in any of the commands, I think the trigggerhappy service already runs as root, so you won't have any permissions problems.
        My advice would be to create a script in /home/pi/scripts/testb.sh, then reference this script in the the button event configuration
        BTN_BASE6 1 /home/pi/scripts/testb.sh
        This way you can modify the script anytime and you don't have to restart the thd service anytime you want to change something in the command to be executed. Give it a try.
          Djon @mitu
          Thanks for your help !
          That is a great idea, poorly i already tested it and it doesn't work aswell...
            Djon
            An "UP" is usefull in this website ?
              Djon
              Can you help me out ?
              I will be very grateful
                mitu Global Moderator @Djon
                @djon I would, but it's a guessing game without having the hardware to test it. It seems the problem is not in the configuration, but something with the service. Is the triggerhappy service running ? What does sudo systemctl status triggerhappy show ?
                  Djon
                  @mitu Thanks for your help, i could be very reactive if you want me to test it quick :)
                  First, triggerhappy don't run as root, anyway i need to do "sudo nano /etc/triggerhappy/triggers.d/testb.conf" (sudo) or the file will be unwritable.
                  ● triggerhappy.service - triggerhappy global hotkey daemon
                  Loaded: loaded (/lib/systemd/system/triggerhappy.service; enabled; vendor pre
                  Active: active (running) since Tue 2018-06-05 23:19:15 UTC; 6 days ago
                  Main PID: 384 (thd)
                  CGroup: /system.slice/triggerhappy.service
                       └─384 /usr/sbin/thd --triggers /etc/triggerhappy/triggers.d/ --socket
                  Jun 12 22:37:00 retropie sudo[1353]: pam_unix(sudo:auth): auth could not identif
                  Jun 12 22:37:02 retropie thd[384]: Executing trigger action: sudo chmod 777 /sys
                  Jun 12 22:37:02 retropie thd[384]: We trust you have received the usual lecture
                  Jun 12 22:37:02 retropie thd[384]: Administrator. It usually boils down to these
                  Jun 12 22:37:02 retropie thd[384]: #1) Respect the privacy of others.
                  Jun 12 22:37:02 retropie thd[384]: #2) Think before you type.
                  Jun 12 22:37:02 retropie thd[384]: #3) With great power comes great responsi
                  Jun 12 22:37:02 retropie thd[384]: sudo: no tty present and no askpass program s
                  Jun 12 22:37:02 retropie sudo[1359]: pam_unix(sudo:auth): conversation failed
                  Jun 12 22:37:02 retropie sudo[1359]: pam_unix(sudo:auth): auth could not identif
                  lines 1-17/17 (END)...skipping...
                  Main PID: 384 (thd)
                  Loaded: loaded (/lib/systemd/system/triggerhappy.service; enabled; vendor preset: enabled)
                  Main PID: 384 (thd)
                         └─384 /usr/sbin/thd --triggers /etc/triggerhappy/triggers.d/ --socket /run/thd.socket --user nobody --deviceglob /dev/input/event*
                  Jun 12 22:37:00 retropie sudo[1353]: pam_unix(sudo:auth): auth could not identify password for [nobody]
                  Jun 12 22:37:02 retropie thd[384]: Executing trigger action: sudo chmod 777 /sys/class/backlight/rpi_backlight/brightness && echo 25 > /sys/class/backlight/rpi_backlight/brightness
                  Jun 12 22:37:02 retropie thd[384]: We trust you have received the usual lecture from the local System
                  Jun 12 22:37:02 retropie thd[384]: Administrator. It usually boils down to these three things:
                  Jun 12 22:37:02 retropie thd[384]: #3) With great power comes great responsibility.
                  Jun 12 22:37:02 retropie thd[384]: sudo: no tty present and no askpass program specified
                  Jun 12 22:37:02 retropie sudo[1359]: pam_unix(sudo:auth): auth could not identify password for [nobody]
                  Hope it can help !
                    Djon
                    It seems to be running but some of the line are in red, here they are :
                      @djon Well, it's clear why this fails: the service doesn't run as root AND the user used to run the service does not have sudo passwordless access. You can see the normal sudo disclaimer in the logs (We trust you have received the usual lecture from the local System..), which is shown whenever a user runs sudo and it must provide the password to run privileged commands. Since your service cannot provide the password, the sudo commands fail.
                      Configure the service to run as rootor as the user pi, and you won't have any problems.
                        Djon
                        Well it looks promising thanks !
                        How can i do it ?? ahah i'm kind of new in the Raspberry family :)
                        Thanks again @mitu
                          @djon said in TriggerHappy Daemon (THD) doesn't work on my Pi running Retropie ! Help:
                          Luckily, this is configurable. Edit the /etc/default/triggerhappy file and uncomment (remove the # ) from the last line. Restart the service via sudo systemctl restart triggerhappy and it should run as root, so you don't need sudo for executing commands.
                          You can also modify the last line and make it run as the pi user (which should be able to run sudo commands without a password prompt), I'd recommend doing that instead of leaving it running as root.
                            Djon
                            Some people say that i need to do
                            "open the configuration file with
                            sudo nano /etc/init.d/triggerhappy
                            modify the configuration file line to look like the following
                            DAEMON_ARGS="--daemon --triggers /etc/triggerhappy/triggers.d/ --socket /var/run/thd.socket --pidfile $PIDFILE --user pi /dev/input/event*" "
                            previously it was : "
                            DAEMON_ARGS="--daemon --triggers /etc/triggerhappy/triggers.d/ --socket /var/run/thd.socket --pidfile $PIDFILE --user nobody /dev/input/event*"
                            But i did it previsouly before asking for help on this forum so i guess i'm missing something !
                              Djon
                              I already tried it in the past, but i'll try it again now
                              let's see
                                Djon
                                The new status, seems to be working on paper @mitu :
                                Active: active (running) since Wed 2018-06-13 02:55:23 UTC; 1min 33s ago
                                Main PID: 752 (thd)
                                       └─752 /usr/sbin/thd --triggers /etc/triggerhappy/triggers.d/ --socket
                                Jun 13 02:55:23 retropie systemd[1]: Starting triggerhappy global hotkey daemon.
                                Jun 13 02:55:23 retropie thd[752]: Unable to parse trigger line:
                                Jun 13 02:55:23 retropie thd[752]: Found socket passed from systemd
                                Jun 13 02:55:23 retropie systemd[1]: Started triggerhappy global hotkey daemon.
                                lines 1-11/11 (END)...skipping...
                                Main PID: 752 (thd)
                                Main PID: 752 (thd)
                                       └─752 /usr/sbin/thd --triggers /etc/triggerhappy/triggers.d/ --socket /run/thd.socket --user nobody --deviceglob /dev/input/event*
                                Jun 13 02:55:23 retropie systemd[1]: Starting triggerhappy global hotkey daemon...
                                  Djon
                                  Now that TriggerHappy seems to be "running well", i think we're close to make it work !
                                  Poorly, when i press the button, nothing seems to be happening...
                                    Djon
                                    FYI: i edited the line as follow: " DAEMON_OPTS"--user pi"
                                      No, it's still not working:
                                      • User running the service seems to be still nobody - probably the configuration file I mentioned works only for the old style service file
                                      • You get an error in the configuration file, which means it's running but ignoring your config.
                                      I think your best bet is to disable the service and run it as the pi user from the autostart.sh file (where Emulationstation is started).
                                      Run it from the terminal, as the pi user with
                                      /usr/sbin/thd --triggers /etc/triggerhappy/triggers.d/ --deviceglob /dev/input/event*
                                      Make sure it works like this - i.e. it gets your button inputs correctly. Then, add the line in either /etc/rc.local or in the autostart.sh script. Make sure you add an & at the end of the command when adding it to either file.
                                        Djon
                                        Waaa we're so close now !!
                                        So when i type
                                        "/usr/sbin/thd --triggers /etc/triggerhappy/triggers.d/ --deviceglob /dev/input/event*" from the terminal and press my button, it actually works !
                                        Now i'm not sure when to add the line, should i do "sudo nano /etc/rc.local" and go at the end and copy and paste ?
                                        FYI, when i type "sudo nano autostart.sh" the file is empty
                                          @djon The autostart.sh file is in /opt/retropie/configs/all/autostart.sh, but try with /etc/rc.local first. You'll need to reboot to test it.
                                            Djon
                                            if the line need to start at boot, i also have a python code running at boot, i added the pyton path at the end of /etc/profile
                                            Don't know if it can help here :)
