    Problem while installing scraper
    scraper errorretropie-setupraspberry pi 1b
    4 Posts 3 Posters 707 Views
      dakiluxa
      Hi, I lost power while trying to install scraper from retropie-setup. When I tried to start installing again, I started getting an error.
      Here's the log output https://hastebin.com/juxatavica.py
      I tried cleaning the source folder (menu option and manually) but the problem persists.
      Any ideas?
      I have a raspberry b (I think it's the oldest one)
      KN4THXK 1 Reply Last reply Reply Quote 0
      • KN4THXK
        KN4THX @dakiluxa
        @dakiluxa Did you try removing the Retropie/tmp contents? Is that how you manually cleaned up the failed install?
        "If you're gonna play the Game Boy, You gotta learn to play it right" - https://www.youtube.com/watch?v=FYLGl92ETNQ
          dakiluxa
          yes that's what I did. I also tried installing golang 1.7 via apt-get but I just noticed the script is using a local 1.8 so it shouldn't be affecting this.
            mitu Global Moderator @dakiluxa
            @dakiluxa Remove the /opt/retropie/supplementary/golang folder and re-try the scraper installation, it should re-install the Go version used by RetroPie. I've seen this kind of errors, due to a mis-installation (or corrupted install) of the Golang package.
