    Can Sound sample in Nestopia use it in Retropie?
    nestopia
    17 Posts 5 Posters 2.8k Views
      A Former User
      Nestopia is supporting special Sound sample of the following game from version 1.30, but is Nestopia in Retropie supporting these samples? If it's being done, I want you to tell me a setting method.
      "Family Trainer - Aerobics Studio" -> "ftaerobi.zip"
      "Moe Pro! '90 - Kandou Hen" -> "moepro90.zip"
      "Moe Pro! - Saikyou Hen" -> "mpsaikyo.zip"
      "Moero!! Pro Tennis" -> "mptennis.zip"
      "Moero!! Pro Yakyuu" -> "moepro.zip"
      "Moero!! Pro Yakyuu '88 - Ketteiban" -> "moepro88.zip"
      "Shin Moero!! Pro Yakyuu" -> "smoepro.zip"
      "Terao no Dosukoi Oozumou" -> "terao.zip"
      edmaul69E 1 Reply Last reply Reply Quote -1
        edmaul69 @A Former User
        @tenmabashi i know you have a language barrier but every time you post “i want you to” you sound demanding. It is not the proper way to ask for help.
        • SanoS
          Sano
          @tenmabashi
          Protip : please replace "I want you to" by "could you please" in your sentences :)
          Your phrasing sounds very rude as it is.
            Yes, you can use sound samples for the Nestopia emulator, have you tried and it didn't work ?
              A Former User @Sano
              @sano sorry
                A Former User @mitu
                @mitu I don't know in which directory is a sound sample files put, and which config file I have to edit.:(
                A sample file was put in the following directory, but that isn't read.
                /roms/nes/samples/morpro.zip
                or
                /bios/nes/samples/morpro.zip
                or
                /bios/nestopia/samples/morpro.zip
                  mitu Global Moderator @A Former User
                  @tenmabashi How about putting them directly under 'bios' or 'nes'.
                    A Former User @mitu
                    @mitu I tried variously, but samples can't be read.:(
                    /bios/samples/moepro.zip
                    /bios/ir-nestopia/samples/moepro.zip
                    /bios/moepro.zip
                    /nes/moepro.zip
                      @tenmabashi I think the proper path should be in the BIOS (under BIOS or BIOS/samples), but for some reason they're not loaded. Hm, I wonder why ..
                      EDIT: could be that the libretro core doesn't support sound samples - so I was wrong assuming it has - but the standalone version seems to load them fine. I'll try to find an answer.
                        OK, it seems that samples are not loaded by the libretro core, it was specific to the Windows version of Nestopia. I was wrong assuming it's included in the core, sorry for giving you false info.
                          Good news, the Nestopia developer ported the sample feature to the libretro core.
                          You can use samples by extracting them to the /home/pi/RetroPie/BIOS/nestopia/samples/<GAME>, where <GAME> is one of the 5 supported games: moepro, moepro88, mptennis, terao, ftaerobi.
                          SanoS H 2 Replies Last reply Reply Quote 2
                          • SanoS
                            Sano @mitu
                            @mitu That's some dedication for sure.
                            Congrats for finding this !
                            • H
                              heroism @mitu
                              @mitu said in Can Sound sample in Nestopia use it in Retropie?:
                              I had try to put these samples zip file to the /home/pi/RetroPie/BIOS/nestopia/samples/ folder.
                              Filename is moepro.zip,moepro88.zip...
                              But it look like no work... When I play game it's always no speak any word, music only .
                              If anyone set up and worked , please tell me how to do this, thanks.
                                mitu Global Moderator @heroism
                                @heroism please read my previous post - you need to extract the samples into their own folder.
                                • H
                                  heroism @mitu
                                  Thank your for reply.
                                  So you mean for example: I play moepro88 game, I should unzip the zip file in to /home/pi/RetroPie/BIOS/nestopia/samples/moepro88/ Folder.
                                  And those files in the folder were look like 01.wav,02.wav...
                                  Or I put moepro88.zip zip file into /home/pi/RetroPie/BIOS/nestopia/samples/moepro88/?
                                  If I can, I will do all the way to try, Thanks.
                                  • H
                                    heroism @heroism
                                    @heroism said in Can Sound sample in Nestopia use it in Retropie?:
                                    I was put zip file and wav file into /home/pi/RetroPie/BIOS/nestopia/samples/<gamename> folder.
                                    It was still no work. By other side, the PC version play sound very well.
                                    I just want to play Janpanese baseball game with perfect sound, maybe I can use PC only...
                                      @heroism Again, you need to unzip the samples in their own game folder for this to work.
