    Super Kuma 9000 power issue
    super kuma 9000power switch
    3 Posts 3 Posters 658 Views
      sixstring396
      Hey everyone. I am having a small problem with my super kuma 9000. It seems that when I plug it in, it automatically starts itself even if the switch is off. Is there a fix for this? I'm running retropie 4.4
      edmaul69E quicksilverQ 2 Replies Last reply Reply Quote 0
        edmaul69 @sixstring396
        @sixstring396 do you plug it straight into the pi and the switch is on the gpio pins? If so, every case i have seen like that powers on as soon as you plug it in. Generally people don’t unplug their system to really have issues with that.
        • quicksilverQ
          quicksilver @sixstring396
          @sixstring396 this is normal behavior. The pi should start to boot, then detect that the switch is in the off position and shut back down.
