    Screen rotation for Retropie GUI
    screen rotation
    20 Posts 9 Posters 20.8k Views
    • eclark5483E
      eclark5483
      So I have a little project in the works since I had so much fun building the last Retropie setup.
      What I am planning on doing, is building a mini cocktail arcade. Project details can be found here: Mini Arcade project
      What this will hopefully end up looking like, is a miniaturized version of the arcade I built my son:
      What I am needing to do, is rotate the screen 90 degrees so that the GUI and of course games, will display correctly. I plan on only using MAME and no other emulators, so I am assuming screen rotation won't be much of an issue there, but I'm wondering about Retropie/Emulation Station itself. Will I need to code my own theme design for it to compensate, is rotation at all possible? Any help is appreciated, thanks.
        blackshadow
        quick copy and paste from another site to save me writing it out lol
        Step 1 – Edit Config.txt
        Start by editing the config.txt file ether via the sd or with:
        sudo nano /boot/config.txt
        Add one of the following lines to the bottom of the file :
        display_rotate=0
        display_rotate=1
        display_rotate=2
        display_rotate=3
        0 is the normal configuration. 1 is 90 degrees. 2 is 180 degress. 3 is 270 degrees.
        If you are using the Official Raspberry Pi touch screen you can use “lcd_rotate” rather than “display_rotate”.
        Save the file by using CTRL-X, Y then ENTER.
        as the site you linked references the 7inch pi screen ill assume thats what your using you can use the lcd_rotate that is mentioned as apposed to display rotate
        • eclark5483E
          eclark5483
          Cool, figured it was probably just a config edit. Now what about the themes themselves? Will rotating change the proportion ratio of the images? And will I need to modify that as well?
            blackshadow
            i would suspect so but i dont personally mess with screen rotation myself in any of my projects though so cant really help in that regard
            • eclark5483E
              eclark5483
              Guess there is only one way to find out, and that's experiment with it. Think I'll do a standard install using the base carbon theme and see what I get. Probably play around with the source code as well. If I find something that works, I'll share that with the retropie team for others to use. If I can't figure it out, well, guess I could always just go with Raspian OS and install MAME that way. Would prefer retropie though, it's a neat little front end/OS.
                mitu Global Moderator @eclark5483
                @eclark5483 RetroPie is not an OS in itelf, it's based on Raspbian (Stretch), so you don't necessarily need to install Raspbian (again) over RetroPie.
                eclark5483E 1 Reply Last reply Reply Quote 0
                • SanoS
                  Sano
                  Beware, IIRC, rotating screen 90° (or 270°) through display_rotate have a quite important performance impact.
                  That said, I don't know if it's still the case.
                  See here for example : https://github.com/raspberrypi/firmware/issues/403#issuecomment-86962019
                  DougAD J 2 Replies Last reply Reply Quote 0
                  • DougAD
                    DougA @Sano
                    @sano I run MAME2003 games in a cabinet with a vertical screen, powered by a Pi 3B , and I haven't seen any performance issues yet.
                    • eclark5483E
                      eclark5483 @mitu
                      @mitu Yes, I realize that. To clarify, I'd rather use the Raspian OS utilizing the Retropie/Emulationstation front end over just plain ole' Raspian without all the bells and whistles.
                        jdrassa @Sano
                        @sano said in Screen rotation for Retropie GUI:
                        EmulationStation now has support for screen rotation to get around this. Details can be found here.
                        Get latest build of EmulationStation for Windows here
                        eclark5483E 1 Reply Last reply Reply Quote 2
                        • eclark5483E
                          eclark5483 @jdrassa
                          @jdrassa One of the things I got from reading that, is that a new theme will indeed need to be made. Can someone point me to the correct folders and files I would need to modify, and what is the theme using? .CSS, .XML? C, etc,etc. Kinda like to research it a bit. Sorry if I'm not well versed in Pi frontends. But I can modify most formats without too much assist. I see many others have authored themes, so I am assuming changing aspects on a custom design wouldn't be too difficult.
                            @eclark5483 https://retropie.org.uk/docs/Creating-Your-Own-EmulationStation-Theme/
                            • eclark5483E
                              eclark5483 @mitu
                              @mitu said in Screen rotation for Retropie GUI:
                              Yes, thank you, exactly what I was looking for. Exactly what I figured needed done as well. This is one of the reasons why I inquired in another topic about Retropie in a virtual machine and transferring files. Hey I love coding, great past time, but I prefer doing it on my Windows 10 PC where I have tools at my disposal that I'm more familiar with. I mean, I can squeak by just fine with Linux and all, guess I'm just spoiled by Redmond. But yeah, thanks for the help. I think I can press forward now.
                                @eclark5483 If you're developing on Windows, check out the ES Toolkit, ES runs also on Windows and you can pretty much do your development exclusively on the PC.
                                • eclark5483E
                                  eclark5483 @mitu
                                  @mitu Thank you, downloading v1.1 right now. Will take a quick look at it tonight. I am only using 1 emulator (MAME), so at least my file structure won't be complex and tedious. I'll probably just do a simple mod of the carbon theme for what I need it for. Then maybe later on down the line when I get bored I'll look at completing other systems.
                                  • eclark5483E
                                    eclark5483
                                    Hey, can I add code to the ES screen that you get when you are configuring your joystick, to ask the user if they would like to rotate/switch resolution and have their selection sent to the correct theme (without needing source code)? Like I said, I'm just gonna mod the carbon code a bit, make it easier for a "per monitor", maybe add a couple other resolution variables that I wouldn't otherwise need but may prove helpful to others.
                                    • SanoS
                                      Sano
                                      @DougA @jdrassa
                                      Thanks for the information guys.
                                      By reading the provided link, I understand that rotating screen via display_rotate (kernel/framebuffer) still has a performance impact, but now ES (as the various emulators do) supports vertical screen (through VG/GL) without this impact.
                                      Good to know.
                                      • JSMJ
                                        JSM
                                        I know this is a necrobump, but I just wanted to say thanks for this. I was trying to run my Retropie in my Arcade1up Galaga cab vertically using that config.txt rotate optino, but the screen tearing was driving me nuts. Downloaded a fresh Retropie 4.5 image, installed the Dev version of Emulation station, and not everything is perfect (except the retropie configs/run command stuff that are rotated 90 degrees!) Seriously - thanks for bumping this thread and adding more info. It was very helpful.
                                          treki
                                          I know, it's a old topic. But still an info:
                                          /boot/config.txt
                                          display_rotate=1
                                          works perfect.
                                          I also have to uncomment:
                                          disable_overscan=1
                                            peterisgb @blackshadow
                                            @blackshadow said in Screen rotation for Retropie GUI:
                                            display_rotate=0
                                            display_rotate=1
                                            display_rotate=2
                                            display_rotate=3
                                            Thanks. This needs the thumbs up as all other routes didnt work. This. Yes. Thanks
