    Audio output doesn't seem all too good anymore *SOLVED*
    audioemulationlr-snes9x2010super nintendo
    5 Posts 3 Posters 1.7k Views
    • AddisonA
      Addison
      Pi 2 with Retropie 4.4 and a standard setup (HDMI to Samsung HDTV).
      I believe all of the audio settings are at their default values and I'm using lr-snes9x2010 for SNES emulation.
      The sound constantly crackles and pops, almost as if there is static noise in the background.
      I'm not running a vacuum or fan or much of anything from the extension cable that my Pi is plugged into.
      Nothing that I can think of that would affect the power going to the Pi.
      Could I perhaps get the preferred audio values that someone here is very happy with?
      System Sound is at 80%.
      Audio Device is set as PCM.
      Alsa Mixer is set to PCM at 44%.
      Default audio settings for the emulator.
      Do I need to overclock a little for better sound quality?
      My Pi already does have a heatsink for this if needed.
      I'm really hoping to hear from someone.
      Please and thank you. :)
        Clyde @Addison
        @addison You could try to add the line audio_pwm_mode=2 to your /boot/config.txt. It made the sound on my Pi 3b much better, but I don't have any experience with a Pi 2.
        Source: https://www.raspberrypi.org/forums/viewtopic.php?f=29&t=136445
        mituM 1 Reply Last reply Reply Quote 1
          mitu Global Moderator @Clyde
          @clyde This is the case when using the 3.5' audio jack. @Addison is your audio going through HDMI or do you have external speakers connected to the Pi audio jack ? If so, then follow @clyde's advice (more details also in https://retropie.org.uk/docs/Sound-Issues/#white-noise-fix).
          AddisonA ClydeC 2 Replies Last reply Reply Quote 2
          • AddisonA
            Addison @mitu
            @mitu Thanks. I bookmarked the link you provided for when I might use headphones.
            It's HDMI straight to the TV with no additional speakers.
            Anyway, I overclocked to 1,000 mghz and the emulator runs perfect now.
            I don't ever remember having any audio issues before but all of that static popping noise is gone again.
              Clyde @mitu
              @mitu Thanks for the addition, I forgot to mention that.
              @Addison As mitu said, my tip doesn't apply to HDMI, sorry.
