    Could not succesfullly build vice - C64 emulator VICE (/home/mac/RetroPie-setup/tmp/build/vice/src/x64 not found).
    vicc64
    7 Posts 4 Posters 774 Views
      macsgv
      Hi, when installing VICE to emulate C64 games in Retropie I find this error and it does not finish installing:
      I am using:
      Linux Mint 19 Tara x86 (32bits)
      RetroPie v4.4.1
      Acer Inspire D250 Netbook
      Will it be because my system is not 64bit?
      Regards!!!
        mitu Global Moderator @macsgv
        @macsgv said in Could not succesfullly build vice - C64 emulator VICE (/home/mac/RetroPie-setup/tmp/build/vice/src/x64 not found).:
        No, it's because of an upstream change (https://sourceforge.net/p/vice-emu/code/35130/). It has nothing to do with your system, this has been reported recently a couple of times in the forums.
          BuZz administrators
          Issues for compiling fuse can be opened here - https://sourceforge.net/p/vice-emu/bugs/ (if there isn't one already for this). Then they can look into fixing it.
            macsgv @mitu
            @mitu Thankyou
              macsgv @BuZz
              This post is deleted!
              • E
                elfoam
                Good to know guys, I was struggling with this the last few days. I'll wait :)
                  You can try now installing Vice, the bug has been fixed and building from source works.
