    Help Making Power Button with Latching Button
    power buttonlatchingpi 3 b+
    4 Posts 3 Posters 975 Views
      saddlepiggy
      Hello! I got all of the electronics I need for an cocktail table (with a Pi 3 B+), except I bought a latching power button instead of a momentary power button, making it kind of difficult to make one easily with GPIO pins.
      When I hit the button the first time, it needs to power it on. At that point the buttons is latched, so when I hit it again, it needs to shutdown properly, as not to corrupt anything
      I don't want to wire it into the PSU cord because then it could cause corruption (right?).
      I think this could be done pretty easily via a script, but I don't know how to implement one into RetroPie. Also I would prefer it to not need a script, but it's not an issue if it makes it work.
      Does anyone know any ways to make this work without buying a new button?
      Thanks, saddlepiggy
      • stoney66S
        stoney66
        I used a script and a switch from mausberry circuits works great.
        https://mausberry-circuits.myshopify.com/pages/setup
          cyperghost @saddlepiggy
          @saddlepiggy You can use the Multi Switch Shutdown Script and call it with --generic parameter. Then you have a basic on/off switch. It does not matter if it's latching or a momentary switch type.
          You can also use the device @stoney66 suggested, with the same script but with parameter --mausberry (imho a very good device). Works also with two types of power switchs (latching or momentary)
            saddlepiggy @cyperghost
            @cyperghost Awesome thank you! I will definitely go with your solution!
