    "es_settings.cfg" not present in "/home/pi/.emulationstation" until first save in EmulationStation menu
    emulationstatonsettings
    1 Posts 1 Posters 2.1k Views
    • hiulitH
      hiulit
      Pi Model or other hardware: (B, B+, 2 B, 3, X86 PC etc..): Virtual Machine with PIXEL (Raspbian X86)
      RetroPie Version Used (eg 3.6, 3.8.1, 4.1 - do not write latest): 4.4.2
      Built From: (Pre made SD Image on RetroPie website, Berryboot, or on top of existing OS etc.. - please provide the filename of any image used) DEBIAN STRETCH WITH RASPBERRY PI DESKTOP https://www.raspberrypi.org/downloads/raspberry-pi-desktop/
      How to replicate the problem:
      I followed the officail guide for installing Retropie in a X86 machine https://github.com/RetroPie/RetroPie-Setup/wiki/Debian.
      After the installation I went to /home/pi/.emulationstation/ and es_settings.cfg wasn't there.
      I had to open EmulationStation, open the menu, change the Theme (I guess any other change might work aswell) and save the changes. Then I went back to /home/pi/.emulationstation/ and es_settings.cfg was there.
      Shouldn't es_settings.cfg always be there?
      Is this the expected behaviour?
      If that's the case, where are all the settings stored when es_settings.cfg is not in /home/pi/.emulationstation/?
      Thank you!
      My little contributions to the RetroPie project:
      • Shell-Script-Boilerplate
      • Fun-Facts-Splashscreens
      • Limit-Last-Played-Games
      • M MSP430 referenced this topic on
