    240p Over Composite to CRT Problems
    240240pcompositecrt
    7 Posts 4 Posters 2.7k Views
    • 2
      240pnoob
      Pi Model or other hardware: 3 B+
      Power Supply used: 2.5 A from CANAKIT
      RetroPie Version Used: 4.4
      Built From: Pre made SD Image on RetroPie website, linked from
      USB Devices connected: flash drive, keyboard ps3 controller
      Controller used: ps3
      Error messages received: NA
      Log found in /dev/shm/runcommand.log (if relevant): NA
      Guide used: Multiple, see below
      File: NA
      Attachment of config files: Will provide if needed
      How to replicate the problem: No idea
      I just made this account to post about the issues I have been having running the latest retropie version with composite video out to a crt. I was under the impression that getting 240p out of this would be a simple task but I STILL haven't managed to do it after reading multiple tutorials and being forced to format the sd card three times because I kept messing stuff up and was unable to fix it.
      I have tried the following methods:
      1. https://github.com/ektgit/snap-shader-240p
      2. https://retropie.org.uk/forum/topic/15737/solved-240p-per-emulator-run-command-setting-possible/3
      3. http://filthypants.blogspot.com/2017/03/raspberry-pi-240p-composite-output.html
      I wasn't able to get anything out of #2 and when I tried #3 I just got black screens when I loaded emulators, sometimes no screen image showed up at all. I came across the first method from this video:
      Now here is the problem; the github link has instructions that are obviously for seasoned users of the device, which I am not. I have no idea where a lot of the settings even are in the part marked "MAKE SURE YOU", I attempted to brute force it and just ended up with black screens again. Could anyone take some screenshots or tell me exactly where to find these settings? Also, what is " /flash/config.txt "? I thought it was "/boot/config.txt"? Is this a typo or an entirely different setting? Any help is appreciated, thanks.
        edmaul69 @240pnoob
        @240pnoob it is a typo. Its /boot/config.txt
        2 1 Reply Last reply Reply Quote 0
        • 2
          240pnoob @edmaul69
          @edmaul69
          ok we're gettin somewhere now
          EDIT: so is there an expert here who knows how to find and modify all the settings listed on the snap shader 240p github page? I tried it once and totally failed
          • 2
            240pnoob
            So after another battle with the pi today I got 240p working with snap shader, however now i cannot read any menus. Alos the scraper doesn't seem to be functioning.....rip
            • SakitoshiS
              Sakitoshi
              I recently created a topic with custom configurations to use retropie on crt tv's with the built-in composite out, maybe that is what you are looking for.
              https://retropie.org.uk/forum/topic/18624/custom-configs-for-crt-using-the-built-in-composite-out
              2 1 Reply Last reply Reply Quote 1
              • 2
                240pnoob @Sakitoshi
                @sakitoshi said in 240p Over Composite to CRT Problems:
                Just checked it out, this has my attention:
                1. install low resolution friendly themes for emulation station (gbz35, gbz35-dark, freeplay, tft, pixel-tft, minilumi and simpler-turtlemini are good ones).
                any easy guides on how to do this? Keep in mind I have only had a raspi for about 24 hours, with 20 of them being me fighting it.
                  mitu Global Moderator @240pnoob
                  @240pnoob said in 240p Over Composite to CRT Problems:
                  You really should read on about the Raspberry Pi and RetroPie in general before trying to customize your installation. Themes can be installed from the RetroPie setup script - https://retropie.org.uk/docs/Themes/.
