    Berzerk with no sound. (Yes I did used samples)
    berzerksoundsmame 2003samples
    5 Posts 2 Posters 1.5k Views
      KeithMason
      Hi,
      I am having trouble with the sounds for Berzerk. I put the Berzerk samples in the sample folder in the bios folder and I don't hear any sound and yes I am using MAME2003. I redownloaded both the rom and the sample and nothing changed. Any clue of what's the problem?
        grant2258 Banned
        the samples should go in bios/mame2003/samples/
          KeithMason
          I did that.
            grant2258 Banned @KeithMason
            @keithmason me and markwidd done some updates to mame2003 on may12 to fix the samples check your on commit 80b83cc if not update from source.
            K 1 Reply Last reply Reply Quote 1
              KeithMason @grant2258
              @grant2258 This worked. Thank you.
