    Sound Delay of 1 second
    sound delay
    13 Posts 5 Posters 2.9k Views
      Pierouge
      Hello, i have a bug : in retropie (menu and retroarch), the sound is delayed of one second
      Here is the runcommand.log : https://pastebin.com/9Fn3c6mH
      I use the latest version of retropie and i have a raspberry pi 3
        mediamogul Global Moderator @Pierouge
        @pierouge
        It could be your television. Make sure all audio/video post-processing features are turned off. Many televisions have a 'Game Mode', others have individual settings and some have both.
        RetroPie is constantly being updated. Sometimes as often as by the hour. Saying that you're using "the latest" doesn't really give us enough information to go on. The required information for a support request is detailed at https://retropie.org.uk/forum/topic/3/read-this-first
          Pierouge @mediamogul
          @mediamogul I tried on another screens like computer screens (same bug)
            @pierouge
            If you could give some more information about your system, as detailed in the link above, it may help with other possibilities.
              Pierouge
              Raspberry pi 3b
              32GB SanDisk MicroSD
              Retropie version 4.4.2
              rbakerR chipsnblipC 2 Replies Last reply Reply Quote 0
              • rbakerR
                rbaker @Pierouge
                @pierouge Are you using an HDMI cable? What resolution is Retropie Set to compared with your TV - more information is needed. It's not something I have seen or experienced.
                  Pierouge @rbaker
                  @rbaker Yes, i use a HDMI cable to my TV (60HZ 1920x1080) in game mode
                  • chipsnblipC
                    chipsnblip @Pierouge
                    @pierouge said in Sound Delay of 1 second:
                    Raspberry pi 3b
                    need more info: https://retropie.org.uk/forum/topic/3/read-this-first
                    please fill out the template so we can better assist you.
                    Pi Model or other hardware: (B, B+, 2 B, 3, X86 PC etc..)
                    Power Supply used: (If using a Pi)
                    RetroPie Version Used (eg 3.6, 3.8.1, 4.1 - do not write latest):
                    Built From: (Pre made SD Image on RetroPie website, Berryboot, or on top of existing OS etc.. - please provide the filename of any image used)
                    USB Devices connected:
                    Controller used:
                    Error messages received:
                    How to replicate the problem:
                      Pierouge @chipsnblip
                      @chipsnblip
                      -Raspberry pi 3B
                      -The Power supply that was in that kit : https://www.amazon.fr/ThePiHut-Raspberry-Starter-Minecraft-Scratch/dp/B01EAQCUQ6/ref=as_sl_pc_tf_til?tag=httpwwwrecalb-21&linkCode=w00&linkId=&creativeASIN=B01EAQCUQ6
                      -Retroipe 4.4.2
                      -Pre made SD Image
                      -Usb SNES Controller
                      -8bitdo SFC30 Gamepad
                      -Nothing
                      -My bug came in emulationstation and emulators
                        Pierouge
                        Oh Wait, i've found a error code :
                        lvl0 : VolumeControl::init() - Failed to find mixer elements!
                          Pierouge
                          Here's a strange thing : reicast omx don't have sound delay
                            Pierouge
                            I alredy tried sdl audio driver, oss, openal and alsa : same bug
                            • KN4THXK
                              KN4THX
                              I actually have the same issue. On my Samsung 46 inch TV connected by hdmi I get a delay of about 1-2 seconds on the ES menu when moving from game to game. I have game mode on the TV.
                              Come to think of it though, I have a Yamaha surround system that I have adjusted the audio delay(lip sync setting) because for some reason the audio was slightly off once I installed the receiver. I just disabled that option on the receiver for the Pi's HDMI output and it seems to be in sync now. Could this be your issue?
                              "If you're gonna play the Game Boy, You gotta learn to play it right" - https://www.youtube.com/watch?v=FYLGl92ETNQ
