    [Solved] "Abuse" (Retropie Porting) does not work
    raspberryretropieabuseportspi3b
    2 Posts 1 Posters 1.1k Views
      shift
      Pi Model or other hardware: Raspberry Pi 3 B
      Power Supply used: 2.5V
      RetroPie Version Used (eg 3.6, 3.8.1, 4.1 - do not write latest): 4.4
      USB Devices connected: keyboard, mouse, joypad
      Controller used: dragonrise
      Error messages received: see below
      Parameters:
      Executing: pushd /opt/retropie/ports/abuse/abuse_datadir; /opt/retropie/ports/ab
      use/abuse; popd
      /opt/retropie/ports/abuse/abuse_datadir ~
      Abuse version 0.9
      Specs : main file set to abuse.spe
      Protocol Installed : UNIX generic TCPIP
      Lisp: 527 symbols defined, 99 system functions, 319 pre-compiled functions
      Joystick : detected
      (load "abuse.lsp") [...................... ]
      (load "abuse.lsp") [................................ ]
      (load "abuse.lsp") [........................................]
      Engine : Registering base graphics
      abuse 0.9
      Sound: Enabled
      1 joysticks on system
      • joystick 0 (controller) : DragonRise Inc. Generic USB Joystick
        No such item nums0016.pcx in file art/icons.spe
      Guide used: n/a
      File: see below
      Emulator: abuse
      Attachment of config files: n/a
      How to replicate the problem: see below
      I installed "Abuse" and the installation was successful, I had to modify the file /opt /retropie/configs/ports /abuse/abuserc under datadir modifying it like this:
      ; Location of the datafiles
      datadir = /opt/retropie/ports/abuse/abuse_datadir
      In the directory abuse_datadir I added all the necessary directories and files taken here: abuse.zoy.org
      I launched the game that does not start returning this error:
      No such item nums0016.pcx in file art / icons.spe
      (The same thing happens with the original DOS game file)
        shift @shift
        Fixed: I downloaded Satan Paint (spaint.exe) and dos4gw.exe (to run spaint.exe under DOS). I used DOSBox to run spaint.exe and I created the .pcx (blank image) that were missing in the icons.spe file (from the nums0016.pcx to the nums0045.pcx), so I created a new icons.spe file and now it works correctly .
        Here is the modified icons.spe file to work: https://github.com/Xenoveritas/abuse/files/2264348/icons.zip
