    Crackling Sound mame2003
    crackling soundmame2013 soundhdmi audio
    28 Posts 10 Posters 7.2k Views
    • U
      und3r6r0und
      Hello gamers!
      I was wondering if you guys could share some of your sound settings and knowledge with me, I mainly play mame78 rom games and I am pretty happy with everything, except the crackling sound. I did a search on this forum and google but it seems like most the the threads are about no sound and I do get sound.
      Raspberry Pi 3 B
      HDMI
      SDL1 driver
      Updated pi 2 days ago.
      again, if you have a sound setting for retroarch or anything that could help me get it a little better sound would be great.
      • rbakerR
        rbaker @und3r6r0und
        @und3r6r0und What power supply are you using?
        • U
          und3r6r0und
          I'm using the one the raspberry one, I don't know the voltage on it.
          • rbakerR
            rbaker @und3r6r0und
            @und3r6r0und You need to look. It must be capable of delivering a stable 5V at 2.5A. If it cannot, the sound will crackle as the Pi struggles to operate.
            • U
              und3r6r0und @rbaker
              @rbaker would it be on the actual adapter?
              • U
                und3r6r0und
                ok, I just looked and it says "Output 5.1V"
                • DarksaviorD
                  Darksavior
                  Which game? Check fps. If it goes under 60 then that causes the crackling audio. Also, a new raspbian update makes a pi3b+ throttle at 60c instead of 70c. Not sure if that affects normal pi3's. Add this to your config.txt : temp_soft_limit=70
                  • rbakerR
                    rbaker @und3r6r0und
                    @und3r6r0und But what about the current?
                    U 1 Reply Last reply Reply Quote 1
                      grant2258 Banned
                      For mame2003 you should really update from source the retropie binary is old. If that doesn't help let me know what games are giving you crackling.
                      • U
                        und3r6r0und @rbaker
                        @rbaker 2.5a
                        • U
                          und3r6r0und @grant2258
                          @grant2258 Final fight is the worse.
                          • rbakerR
                            rbaker @und3r6r0und
                            @und3r6r0und So your power supply is ok which leads you to the HDMI cable and settings next. I use the 3.5 jack and have never had crackle unless you are stressing the CPU with games that can't be handled by the hardware.
                            KN4THXK 1 Reply Last reply Reply Quote 0
                            • KN4THXK
                              KN4THX @rbaker
                              @rbaker May I ask what application makes the 3.5mm jack a preferable audio source? Do you run Retropie on a monitor without sound? I've always wanted to use it for a purpose to say I've used all of the ports but on my television the HDMI handles it all.
                              "If you're gonna play the Game Boy, You gotta learn to play it right" - https://www.youtube.com/watch?v=FYLGl92ETNQ
                                grant2258 Banned @und3r6r0und
                                @und3r6r0und ill compile the latest on the pi and test(i usually test on linux or windows for development). I just done some updates to mame2003 a few days ago ill make sure its isint that causing it.
                                Please make sure your using the latest mame from source.
                                update compiled the latest mame source and its all good my end on a pi3 b+
                                I had problems myself when using the audio jack our resident pi guru has advice on a fix for this.
                                https://retropie.org.uk/forum/topic/17828/rampage-sound-issue-retropie-4-4/3
                                • rbakerR
                                  rbaker @KN4THX
                                  @thedatacereal I use Retropie in an arcade cabinet with a 19" monitor. I then use a hacked apart old set of speakers with a built in amplifier. See this photo. This plugs straight into the 3.5 inch jack plug. Once you set up Retropie, there is a bit of tweaking to be done. First, I set the volume in setup to about 75%. I then edit the config files according to this link. I use 75% instead of 100% as the amplifier acts as a very good inline volume control. The results are of a high quality if the amplifier that you choose is decent in terms of both gain and noise suppression.
                                  • markwkiddM
                                    markwkidd
                                    @BuZz here is one issue that would be solved by updating the mame2003 binary
                                      BuZz administrators @markwkidd
                                      @markwkidd Not sure if you are intentionally trying to wind me up ? You have tagged me in three different threads with the same message?
                                      • markwkiddM
                                        markwkidd
                                        First I stared with a plain github issue. You asked instead to be tagged in the forums to help explain why I'm asking for a binary update. These are all threads that I'm monitoring because of issues relating to the build date of the mame2003 binary.
                                        I could have just tagged you in only one of them, but then we might as well have talked about it in the issue. I apologize that my communication style is seemingly different than yours.
                                          @markwkidd The issue tracker clearly says to use the forum first and if directed then open an issue. You ignored that when opening an issue.
                                          I then asked you to tag me if you need something updated that you think is important. I also said I had already seen the thread. I didn't ask you to tag me three times with the same request in three different threads (with one being totally unrelated as it was already confirmed not a problem with the binary).
                                          It's not difficult.
                                          markwkiddM 1 Reply Last reply Reply Quote 0
                                          • markwkiddM
                                            markwkidd @BuZz
                                            @BuZz said in Crackling Sound mame2003:
                                            It's not difficult.
                                            I would not agree that ignored those instructions and I find your tone very discourteous considering that we are peers -- both people who volunteer substantial amounts of time to helping make RetroPie a positive experience for users.
                                            I'm not interested in arguing the nuances of whether I followed your instructions. I will simply say that -- as someone who also receives many notifications from users every day about my emulator work -- that your policies for how people can communicate with you are a little beyond the pale.
                                            Please feel free to ignore me but I will tell you a fellow volunteer developer, I don't benefit from you taking the time to write me one sentence back if it is purely to critique my communication approach.
