    My First Gameboy Zero with Teensey LC Build, Help Please...
    gameboy zeroteensy lc
    1 Posts 1 Posters 548 Views
    • KorsaK
      Korsa
      Hi all, so I've attempted my first GBZ build, purchased all the parts and had a tinker. Everything seems to be working fine, programmed the Teensy correctly (it recognises keystrokes on the PC) but whenever I plug it into the Pi Zero it will compile some check and ask me for a keyboard to press enter on completion.
      If I boot with a USB splitter so Teensy and a Keyboard connected I'm able to press enter after the check but then when it boots into PetroPie the Teensy doesn't give off any inputs, only the keyboard will control it.
      And obviously if I just boot with a keyboard I can control it fine, and It will not even do the disk check.
      This is all without hardwiring it for now, I'm just using the Teensy connected through the Pi Zero's USB port (Eventually it will be hard wired).
      Can anyone with experience shed any light on this for me?
      Many thanks! :)
      Pics Below
      https://ibb.co/cS9Zt9
      https://ibb.co/d83G6U
