No sound in-game.
Hello everyone, I got sound from video snaps in menu but none in-game. How is that possible haha. Anyway, i googled for two hours yesterday and i could not get this issue fixed. Running 4.4 of course with 3 not plus( should i upgrade?)
Ok here is what i did yesterday, hdmi drive is uncommented and set to 2. Inside ES's raspberry menu i set audio to hdmi, i tried to changed retroarch config to sdl2, alsa, alsa thread... still no sound.
No sound for any system, arcade, genesis, nes etc...
Oh god(YOU), please help meeee!
@eldgrim Please fill out the information requested in https://retropie.org.uk/forum/topic/3/read-this-first.
Pi Model or other hardware: 3
Power Supply used: Micro USB 2,5 A from CanaKit
RetroPie Version Used (eg 3.6, 3.8.1, 4.1 - do not write latest): 4.4
Built From: https://retropie.org.uk/download/
USB Devices connected: none
Controller used: 2x ibuffalo controllers and 2x ps4 with their official usb dongle.
Error messages received: none
Guide used: random google fu, explained in first post.
File: none
Emulator: all
Attachment of config files: will edit my post later today with it
How to replicate the problem: just play anything -
Can you try increasing the system's sound volume from a SSH or command line using
alsamixer
? I know it sounds stupid, but maybe the default volume is too low for you to hear it.
Otherwise, you can enable verbose logging when starting a ROM with the Runcommand launch menu (https://retropie.org.uk/docs/Runcommand/#runcommand-launch-menu), play a bit, then exit and get the/dev/shm/runcommand.log
file. Paste the contents of the file to pastebin.com so we can take a look at it.
