    Help Pairing Xbox One bluetooth controller. Keeps asking for pin
    xboxonecontrollerbluetoothpairingissues
    3 Posts 2 Posters 1.0k Views
      sirus505
      Hi
      I am having trouble getting my Xbox one controller setup with retropie. Everytime I try pairing via bluetooth but it aska for a pin of 0000 or something I would need. Obvious problem is you cant type the pin on the controller and using a keyboard doesn't help either. So I am getting an unauthorised error.
      Things I have tried.
      Updated controller's firmware.
      Update retropie with script and using update and upgrade on command line.
      Tried using different bluetooth dongles too but not luck.
      My setup is Rpi 2b
      controller is an xbox one model 1708
      Any idea on what I can try doing? Cheers.
        mitu Global Moderator @sirus505
        @sirus505 What RetroPie release are you using and how did you install it ?
          sirus505
          Hi.
          I am on v4.4 and got it by getting downloading the image onto my sd card.
