    retropie 3.8.1 and kodi 16
    31 Posts 5 Posters 15.3k Views
      alfredox123
      i have metro pcs 2.1a charger with 2 usb on it for charging 2 things at the same time, i only use for the raspebrry pi, i dont think is power related because it works fine with the controller and a keyaboard on both usb, but when i put only the controller it reboots infinitly so theres something wrong with my controller, when retropie recognizes my controller it says gasia corp which i think are the fake ps3 controllers? fake ps3 controllers doesnt work well with kodi 16.1?
      • herb_fargusH
        herb_fargus administrators @alfredox123
        @alfredox123 there have been some controller incompatibilities that have caused crashes particularly Bluetooth ones.
          alfredox123
          pi model: 1 B
          retropie version: 4.0 dev
          built from: sd image retropie 3.8.1
          usb devices connected: 1
          controller used: dream gear arcade fighter pad
          error message recieved: reboot infinite when using dream gear arcade fighter pad with kodi 16.1
          atttachment of config file: http://pastebin.com/SajFfQkD
          how to replicate the problem: use a dreamgear arcade fighter controller when executing kodi 16.1 on retropie 4.0 dev
          • herb_fargusH
            herb_fargus administrators @Rascas
            @Rascas is it possible it's doing the same thing that caused the crash when I added the xboxdrv? I wonder if he removed the Xbox config we add by default will fix his issues
            RascasR 1 Reply Last reply Reply Quote 0
              alfredox123
              how i check that? i didnt remove anything except for roms of my games and that was a while ago :s
              • RascasR
                Rascas @herb_fargus
                @herb_fargus I don't think so, after we changed the xbox 360 xml the crash was fixed. Kodi 16.1 wasn't changed anymore, and alfredox123 has the latest version already.
                @alfredox123 Try using a clean Kodi config. Move or remove /home/pi/.kodi
                You are also using a PSU with a separate USB cable + overclocking and that can also be problematic. Try with a single piece PSU and without overclocking.
                The Gasia controller and your other controller aren't supported OOTB. Check the RetroPie and Kodi wikis to learn how to create a custom configs for both. The Gasia controller is confirmed to be working with a custom config, altough it was tested some time ago.
                  alfredox123
                  tried removing .kodi folder but didnt work, tried using default clocks but didnt work either. i dont have another psu that can power my rpi1 but theres no other thing on the other female space usb (the psu have 2 usb female holes, not two cables). and the gasia corp controller is the dreamgear arcade fighter pad, retropie refers to gasia corp controller as the dreamgear arcade fighter pad. anything else i could try?
                    alfredox123
                    btw the dreamgear arcade fighter pad works great with keyboard attached on the other usb of the rpi1 (if i disconnect the controller when kodi is executing and after is completly running i plug the controller) all buttons works in the kodi menu so i dont need a custom config?
                      alfredox123
                      in a few days should arrive my genuine ps3 controller, will try it to see if the problem is because the dreamgear arcade fighter pad is based on a fake ps3 controller
                        alfredox123
                        today i got my genuine ps3 controller and all works great with kodi and de ps3 controller, even on bluetooth. that means that kodi 16.1 has problems with ps3 controllers labeled as gasia corp controllers (fake ones)
                        • herb_fargusH
                          @alfredox123 that's good to know
