    Override Mouse index in Mame2003?
    override
    4 Posts 2 Posters 672 Views
      mha
      I have set mouse index in retroarch.cfg to
      input_player1_mouse_index = "0"
      Need to override this for Bombee & Arcanoid roms (only) to
      input_player1_mouse_index = "2"
      Can You please advice me, how to activate those overrides?
      THX!
        mediamogul Global Moderator @mha
        @mha
        You'll need to create a text file with a .cfg extension and the same name as your game in the directory your game is located. So, for example, if your game is named Arkanoid.zip, you'd name your text file Arkanoid.zip.cfg. In there, you'll add...
        ... and you should be good to go.
          mha @mediamogul
          @mediamogul Thanks for Your effort!
          Will give it a try tomorrow.
            mha @mediamogul
            @mediamogul said in Override Mouse index in Mame2003?:
            It works like a charm :)
            A big hand to You!
