    Retroflag Snes case
    raspberry pi3casepowerblock
    55 Posts 13 Posters 19.2k Views
      Chuck_B
      Hi guys, I hope I'm not too off-topic, but I have no idea ho ask about that.
      I was wondering if the snes retroflag case switch works as a powerblock.
      I mean, one of the most annoying things about the Raspberry is that everytime you plug it, it boots automatically.
      With the retroglag snes case (I'm referring to the PAL version) if I plug the raspberry but the switch of the case is set to off, retropie boots anyway or it blocks the booting until I switch it on?
      lostlessL R 2 Replies Last reply Reply Quote 0
      • jandalf81J
        jandalf81
        I just tested this with my case: It will only boot when the POWER switch is set to ON.
        • lostlessL
          lostless @Chuck_B
          @chuck_b there’s a switch inside that sets it to safe power/shutdown or the symptom you are mentioning. Check to see if that switch is set to safe shutdown.
            Chuck_B @jandalf81
            @jandalf81 you talk about the external switch, not the internal safe switch, right?
            @lostless I don't have one, I'm asking before I buy it :)
            • jandalf81J
              jandalf81
              Yeah, sorry. I could have expressed myself better here...
              To clarify:
              The case comes with an internal board, see http://retroflag.com/SUPERPi-CASE-J.html
              There's two switches and one button on that board:
              • POWER (ON / OFF)
              • SAFE SHUTDOWN (ON / OFF)
              • RESET
              Also, the power is being routed through this internal board. So, I have set the SAFE SHUTDOWN to ON and installed the script from the official website https://github.com/RetroFlag/retroflag-picase
              This way, the fan starts spinning when you set the POWER switch to ON (and doesn't stop while the Pi is powered on). The script will shut down the Pi and stop the fan when it detects the POWER switch being set to OFF.
              HurricaneFanH cyperghostC C 3 Replies Last reply Reply Quote 0
              • HurricaneFanH
                HurricaneFan @jandalf81
                @jandalf81 If you don't use the fan port on the pcb, will the shutdown scripts still work?
                I'm having trouble using a fan on ports 17, 20 on the gpio. Fan works but hitting power button just turns the whole device off, with no safe shutdown.
                  cyperghost @jandalf81
                  @jandalf81 said in Retroflag Snes case:
                  Better use
                  https://github.com/crcerror/retroflag-picase
                  lostlessL HurricaneFanH P 3 Replies Last reply Reply Quote 1
                  • lostlessL
                    lostless @cyperghost
                    @cyperghost ya, your script works great. Thanks
                    • HurricaneFanH
                      HurricaneFan @cyperghost
                      @cyperghost Does this work with 3B+? Cause I'm not getting safe shutdown.
                        cyperghost @HurricaneFan
                        @hurricanefan It works as long as you use RetroPie with ES. It is the same python code as retroflag uses with some improvements. I suggest to put the switch in correct position. So retroflag code uses killall command and then safe shutdown fails if an emulator is running. This avoids the script written by me.
                        HurricaneFanH 1 Reply Last reply Reply Quote 0
                        • HurricaneFanH
                          @cyperghost I am using retropie 4.4 image with all packages updated, I have a pi 3b+ and the safe shutdown switch is set to ON. Any time I hit the power button it just kills all power to the device. No safe shutdown.
                            cyperghost
                            @HurricaneFan Is there a sudden powerdown like you pull the power cord? If no then try my script. If yes then the switch seems not working
                            • HurricaneFanH
                              @cyperghost Yeah, it acts like I totally powered down like a cord pull. I switched the python file to yours and I get the same behavior. So bad switch might be possible.
                                @hurricanefan I've read about wrong soldered switch, maybe you set safe shutdown to off and try this? Some users reported issues here
                                • HurricaneFanH
                                  @cyperghost I tried putting the switch back to off and it doesn't work either. Its as if the switch doesn't do anything at all when its on.
                                  • HurricaneFanH
                                    HurricaneFan @HurricaneFan
                                    Sounds like its something to do with pi 3b+ models.
                                      @hurricanefan Do you have annother Pie? It's not the layout of the GPIOs or so... So I think it's rather something with the case.
                                      HurricaneFanH 2 Replies Last reply Reply Quote 0
                                      • HurricaneFanH
                                        @cyperghost I have a pi 3b thats screwed into another case. I'll try to test that shortly.
                                          Chuck_B @jandalf81
                                          And Retropie starts only when I set the POWER SWITCH to ON. Correct?
                                          • HurricaneFanH
                                            @cyperghost So just finished testing with the same sd card and a pi 3b (not plus) and the safe shutdown and reset code works just fine. The pi 3b+ has something that doesn't like the shutdown/reset code. Super weird!!
                                            lostlessL cyperghostC 2 Replies Last reply Reply Quote 0
