    X-Arcade Right side button issue
    x-arcadexarcadexarcade2jstickpinball
    22 Posts 6 Posters 5.0k Views
    • LurkerL
      Lurker
      Another fun question.
      Are you moving around the wires in between tests?
      I ask because of the two pictures. The first picture clearly has a daisy chained orange wire on the NO pin and brown wire on the com pin. But in the second picture the wires have been swapped with the near by top facing button. It looks like you swapped the buttons, which can be a good way to test the button and see if the issue follow to the new button.
      It is not critical at the moment but I thought I would note it in case you suddenly find that the other button is now acting weird.
        ChuckyP
        With that new angle it looks like they only split the button from the player 1 control panel to the side button for pinball.
        So that shouldn’t cause any problems. Hope you get it sorted out.
