    Shifting gear in Outrun?
    6 Posts 4 Posters 9.2k Views
    • PingSpikeP
      PingSpike
      Does anyone play Outrun on mame?
      How the heck do I change gear from Lo to Hi?!
      (Using keyboard controller / ipac2)
      Here's my RetroStation project - http://www.pingspike.com/retrostation-part-4/
      :D
      whsiungW C 2 Replies Last reply Reply Quote 0
      • whsiungW
        whsiung @PingSpike
        @PingSpike Did a quick test here, I think it's P1 Button 4 in the in game configuration menu. So depend on which button you assign to P1 Botton 4 :)
        Edit: Forget to mention - it's mame2003.
        WH
        PingSpikeP 1 Reply Last reply Reply Quote 1
          RetroResolution
          I was playing this a the weekend under lr-imame - it was the Triangle button (PlayStation Dualshock) to shift UP, and the Square button to change Down, which isn't exactly the most natural mapping, unfortunately.
          • PingSpikeP
            PingSpike @whsiung
            @whsiung Spot on mate!
            Sure enough, button 4 does indeed engage 'Hi' gear!!
            It also turns out that button 3 engages 'Lo' gear too.
            So with a quick mod on the game input settings to suit my arcade controls we're all set!
            I can now get to stage two of the game, this is AMAZING news, thanks so much :)
            @RetroResolution are you able to change the mapping of yours to something more natural?
            :D
              RetroResolution @PingSpike
              @PingSpike Hi,
              I didn't try, but as I'm running the libretro version of Mame it would be pretty straightforward to change the button mapping through the RetroArch GUI.
              For a non-libretro core, it'd be slightly more involved, but with a little config file editing it wouldn't be too hard to achieve.
              Btw - nice RetroStation project, very impressive!
                chavatar @PingSpike
                @PingSpike Fi you haven't seen it - Cannonball is simply awesome. Easy config too.
                I dream one day of building my own cabinet - just like an orginal, but without the brake pedal ;)
