    Problems with cheats in lr-mame2003 (SOLVED)
    cheatslr-mame2003mame-libretro
    3 Posts 2 Posters 2.5k Views
    • saccublendaS
      saccublenda
      I have a problem in enabling cheat codes for lr-mame2003.
      I have the cheat.dat file in the /home/pi/RetroPie/BIOS/mame2003/directory, I have set:
      mame2003-cheats = "enabled"
      in /opt/retropie/configs/all/retroarch-core-options.cfg, and I have
      cheat_database_path = "~/RetroPie/BIOS/mame2003"
      in /opt/retropie/configs/mame-libretro2003/retroarch.cfg. However, when I bring up the MAME menu by pressing Tab, I go to "Cheat" -> "Enable/Disable a Cheat", and I get the message:
      "cheat database not found - unzip it and place it in the MAME directory"
      Am I missing something?
      Pi Model or other hardware: 3
      Power Supply used: USB3.0
      RetroPie Version Used: 4.4.2
      USB Devices connected: 1x Keyboard / 1x Controller
      Controller used: 8bitdo sfc30 (bluetooth)
      • saccublendaS
        saccublenda
        I solved this.
        Apparently neither the mame2003-cheats nor the cheat_database_pathsettings are required for the mame cheats to work, the only thing that is needed (beside the cheat.dat file in /home/pi/RetroPie/BIOS/mame2003) is to set system_directory = "~/RetroPie/BIOS" in /opt/retropie/configs/mame-libretro2003/retroarch.cfg.
          grant2258 Banned
          nothing needs setup the default retropie config is set to
          system_directory = "~/RetroPie/BIOS" your problems are arising from messing with the default config , you need to be careful when changing the configs on retropie.
          retropies default mame install copies the the cheat dat from here https://github.com/libretro/mame2003-libretro/tree/master/metadata to the bios folder on install. your not supposed to save retroarch configs with retropie unless you know what you are doing fully. The cheats do work on a default install nothing needs done.
