    [SOLVED] - Final Burn Alpha (lr-fbalpha) not playing rom sound samples file
    finalburn alpharetropie 4.4lr-fbalphasamples
    4 Posts 2 Posters 3.4k Views
    • W
      wiggy808
      Pi Model or other hardware: B+
      RetroPie Version: 4.4.2
      USB Devices connected: X-Arcade Joystick / Keyboard
      Guide used: https://github.com/RetroPie/RetroPie-Setup/wiki/FinalBurn-Alpha
      File: /home/pi/RetroPie/BIOS/fba/samples/dkong.zip
      Emulator: lr-fbalpha
      Donkey Kong rom sound samples are not playing. Per the guide, the samples should be same name and in the directory specified. They are, I've restarted ES, but still no samples (movement, jumping, etc.) play during the game. I've unzipped the file, the 3 sound effects are in there and play fine on my PC.
      Below is the output of the samples and rom directories for dkong.zip.
      pi@retropie:~ $ ls -larth /home/pi/RetroPie/BIOS/fba/samples/
      total 16K
      drwxr-xr-x 3 pi pi 4.0K Sep 21  2017 ..
      -rw-r--r-- 1 pi pi 6.3K Sep 19 15:28 dkong.zip
      drwxr-xr-x 2 pi pi 4.0K Sep 26 02:48 .
      pi@retropie:~ $ ls -larth /home/pi/RetroPie/roms/fba/dkong.zip
      -rw-r--r-- 1 pi pi 22K Apr 25  2016 /home/pi/RetroPie/roms/fba/dkong.zip
      pi@retropie:~ $
        barbudreadmon @wiggy808
        @wiggy808 your dkong samples file is definitely wrong (probably targeted at a recent mame version where most sounds don't need samples anymore), it should be a lot bigger than 6.3k. Well, i don't think there are legal issues with sharing those wav files (if there are, please delete/edit my post), so try this one : https://www.sendspace.com/file/y3d1kg
        W 1 Reply Last reply Reply Quote 1
        • W
          wiggy808 @barbudreadmon
          @barbudreadmon
          That was the problem, many thanks!
          Is there a clrmame or other program that can check the samples files to let me know they are incorrect / incompatible?
            @wiggy808 said in [SOLVED] - Final Burn Alpha (lr-fbalpha) not playing rom sound samples file:
            The list of needed wav files is included in the dats i provide at https://github.com/libretro/fbalpha/tree/master/dats . Clrmamepro should be able to tell you if you have all needed wav files if you setup "Sample-Paths" in Settings, then check "Samples" in the scanner, it'll only check filenames though, not crc.
