    problem with Bluetooth dongle and a RP1A
    usbbluetooth
    1 Posts 1 Posters 187 Views
      mikgus
      I have a RP1A and using a 8bitdo zero. With only one usb port i use a usb hub while setting everything up.
      Everything works fine when using the hub but when i use the Bluetooth dongle direct in the raspberry, the controller cant sync with the dongle.
      What change when the dongle moves? And how do i allow for the controller when the dongle is connected direct to the raspberry pi?
      i don't have any BT keyboard so all changes have to be done with the hub connected.
      retropie 4.14.30+ #1102
      Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
      Bus 001 Device 003: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
