    Xbox One Wireless Adaptor Connection
    xbox one contro
    41 Posts 13 Posters 29.6k Views
      mitu Global Moderator @LeSabotageur
      @LeSabotageur said in Xbox One Wireless Adaptor Connection:
      @mitu : do you know if there's any plan to officially embed xow in future retropie releases ?
      No, it's not right now - but I looked at the it and it shouldn't be difficult to add it as a scriptmodule. But I'm not sure about the maturity of the driver and the fact that includes a non-free/non-open source firmware blob.
      MediaTek Inc. grants permission to use and redistribute aforementioned firmware
      files for the use with devices containing MediaTek chipsets, but not as part of
      the Linux kernel or in any other form which would require these files themselves
      to be covered by the terms of the GNU General Public License or the GNU Lesser
      General Public License.
      These firmware files are distributed in the hope that they will be useful, but
      are provided WITHOUT ANY WARRANTY, INCLUDING BUT NOT LIMITED TO IMPLIED WARRANTY
      OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE.
      • L
        LeSabotageur @mitu
        @mitu Yeah I guess technically it should be fairly simple; as for the license regarding the firmware.bin, I saw it discussed there : https://github.com/medusalix/xow/issues/15 if that may help.
          @LeSabotageur Thank you for the pointer - it's helpful to get the perspective from the a Debian packager. I see the package is uploaded to sid (https://packages.debian.org/sid/xow), though only for amd64. I wonder if the firmware is not already distributed as part of one of the several firmware packages included in the Debian/Ubuntu non-free repository section.
          • L
            LeSabotageur @mitu
            @mitu You're very welcome; for further information, there's a list of several current releases on https://github.com/medusalix/xow, listing Debian, Arch Linux, EmuELEC, GamerOS and Steam Link.
            I wouldn't know however if the licenses there are similar to Retropie's (or if the respective distributors care enough about that, for that matter; I sure hope they do).
            • L
              liondog @LeSabotageur
              @LeSabotageur Can you share the installation steps? I follow the instructions in the portal but got error when run makefile.
              • L
                LeSabotageur @liondog
                @liondog I've followed the installation instructions there : https://github.com/medusalix/xow , launched manually xow to check if the controller was connecting correctly, then rebooted and the controller was usable in retropie.
                I didn't have a problem running makefile; do you have the prerequisites listed, especially libusb ? What's the error shown ?
                • CobraKaiC
                  CobraKai
                  @LeSabotageur and @mitu I was wondering if the Xbox One Wireless Adapter driver was packaged for Retropie yet?
                  I also was wondering how it is working any latency issues and is it better than connecting the Xbox One Controller via bluetooth?
                  Trying to figure out the prerequisites to install this to a Retropie image that I obtained that was built a few months ago.
                  Any advice or steps to do this I would appreciate it, kind of new to all of this.
                    mitu Global Moderator @CobraKai
                    @CobraKai said in Xbox One Wireless Adaptor Connection:
                    No, it's not, but you can install it manually - it's not that difficult.
                    CobraKaiC 1 Reply Last reply Reply Quote 0
                    • CobraKaiC
                      CobraKai @mitu
                      @mitu do you know if i have to install anything prior, I am using a RetroImage prebuilt that was done 2 months ago.
                        @CobraKai We don't support 3rd party images - ask the author of the image or just try it out yourself.
                        • CobraKaiC
                          CobraKai @mitu
                          @mitu Does this work with the Raspberry Pi 4 Model B?
                          • CobraKaiC
                            CobraKai @CobraKai
                            @mitu and @LeSabotageur
                            I am trying to install on my Raspberry Pi 4 Model B I have installed the latest Raspbain OS Buster Image.
                            I want to install this driver to see if I can get my Xbox One Wireless controller to work with my Xbox Wireless Dongle.
                            I am a real noob regarding Linux, so steps necessary to do this would help me out.
                            i could contribute $20 to someone if it solves my request. I would have to test it out first, but being that it would save me from using a different controller and I prefer my Xbox One Wireless controller I would definitely contribute to someone to help me.
                            Here is my info on my build:
                            i@raspberrypi:~ $ cat /etc/os-release
                            PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
                            NAME="Raspbian GNU/Linux"
                            VERSION_ID="10"
                            VERSION="10 (buster)"
                            VERSION_CODENAME=buster
                            ID=raspbian
                            ID_LIKE=debian
                            HOME_URL="http://www.raspbian.org/"
                            SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                            BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                            pi@raspberrypi:~ $ lsb_release -a
                            No LSB modules are available.
                            Distributor ID: Raspbian
                            Description: Raspbian GNU/Linux 10 (buster)
                            Release: 10
                            Codename: buster
                            pi@raspberrypi:~ $ cat /proc/version
                            Linux version 4.19.97-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1294 SMP Thu Jan 30 13:21:14 GMT 2020
                            • thediebatzT
                              thediebatz
                              I have done it on my newly setup Retopie on an Raspberry Pi 4 Model B
                              Go in the commandline and follow this instructions:
                              GET cabextract OTHERWISE command make BUILD=RELEASE will fail
                              sudo apt-get install -y cabextrac
                              GET XOW AND INSTALL
                              git clone https://github.com/medusalix/xow
                              cd xow
                              make BUILD=RELEASE
                              sudo make install
                              sudo systemctl enable xow
                              sudo systemctl start xow
                              Reboot Pie
                              sudo reboot
                              Get your USB-Stick in Paring-Mode
                              sudo systemctl kill -s SIGUSR1 xow
                              After this command your Stick should start to make bling bling and you can pair yourself with it!
                              Regards
                                suhrmajesty
                                When I try git clone https://github.com/medusalix/now using Raspberry Pi 4 4gb with retropie-buster-4.7-rpi4.img
                                I get a prompt to put in a Username and Password I tried my GitHub username and password and get an Invalid
                                Username or Password Fata: Authentication failed for 'https://github.com/mcusalix/xow/'
                                When I try this command in Linux Mint everything works as it should. I'm new to Linux so not sure what to do to get past this.
                                  mitu Global Moderator @suhrmajesty
                                  https://github.com/medusalix/now...
                                  This is the wrong repository - it's https://github.com/medusalix/xow. Github will ask for user/pass when it doesn't find a public repository at the given URL.
                                  S S 2 Replies Last reply Reply Quote 0
                                    suhrmajesty @mitu
                                    @mitu Thank you!
                                      soultaker @mitu
                                      @mitu Hi All, appreciate the help from this forum. I was able to connect one of my xbox one controllers to the wireless adapter for retropie, but the other will not pair. Both controllers are model 1697. Any ideas?
                                      • L
                                        liquidchild101
                                        Hi Everyone,
                                        I dont have any linux knowledge but I would love to get my xbox controller working wirelessly on Retropie (most up todate).
                                        using a pi4 4gb
                                        I tried to use the above instructions from @thediebatz but ive run in some errors.
                                        **Im guessing this is my first problem.
                                        pi@retropie:~ $ sudo apt-get install -y cabextrac
                                        Reading package lists... Done
                                        Building dependency tree
                                        Reading state information... Done
                                        E: Unable to locate package cabextrac
                                        **I expect All the rest of the instructions dont work because of "unable to locate" error I got.
                                        **but I've run through the rest, just incase its fine.
                                        pi@retropie:~ $ git clone https://github.com/medusalix/xow
                                        fatal: destination path 'xow' already exists and is not an empty directory.
                                        pi@retropie:~ $ cd xow
                                        pi@retropie:~/xow $ make BUILD=RELEASE
                                        curl -o driver.cab http://download.windowsupdate.com/c/msdownload/update/driver/drvs/2017/07/1cd6a87c-623f-4407-a52d-c31be49e925c_e19f60808bdcbfbd3c3df6be3e71ffc52e43261e.cab
                                        % Total % Received % Xferd Average Speed Time Time Time Current
                                        Dload Upload Total Spent Left Speed
                                        100 195k 100 195k 0 0 3424k 0 --:--:-- --:--:-- --:--:-- 3485k
                                        cabextract -F FW_ACC_00U.bin driver.cab
                                        make: cabextract: Command not found
                                        make: *** [Makefile:39: firmware.bin] Error 127
                                        pi@retropie:~/xow $ sudo make install
                                        100 195k 100 195k 0 0 526k 0 --:--:-- --:--:-- --:--:-- 524k
                                        pi@retropie:~/xow $ sudo systemctl enable xow
                                        Failed to enable unit: Unit file xow.service does not exist.
                                        pi@retropie:~/xow $ sudo systemctl start xow
                                        Failed to start xow.service: Unit xow.service not found.
                                        pi@retropie:~/xow $
                                        **reboot works but then
                                        pi@retropie:~ $ sudo systemctl kill -s SIGUSR1 xow
                                        Failed to kill unit xow.service: Unit xow.service not loaded.
                                        pi@retropie:~ $
                                        **I know my 0% knowledge of linux is to blame but any help would be greatly appreciated
                                        Cheers
                                          @liquidchild101 said in Xbox One Wireless Adaptor Connection:
                                          You need to install the cabextract package first with
                                          sudo apt -y install cabextract
                                          This is described in the installation instructions for xow.
                                          L 1 Reply Last reply Reply Quote 1
                                          • L
                                            liquidchild101 @mitu
                                            @mitu Thank you so much. that worked like a charm.
                                            I've gotta so used to wireless. Going back to wired is such a pain now.
                                            cheers mate!
