    Issues with PowerBlock build installation
    powerblockbuild failedmakepowerblock mod
    2 Posts 1 Posters 724 Views
      CDStrange
      Hello all! I have been having this issues with my PowerBlock regarding the software installation. Following the tutorials, I have gotten as far as the make command. However, the make seems to be running into an error part way into the build.
      It seems similar (but not exact) to another build error I saw on this forum. Dropping the link here: https://retropie.org.uk/forum/topic/16944/powerblock-drivers-not-downloading-correctly
      Here is the return from the console where things start going sour: https://pastebin.com/khrKTknR
      I hope this helps, I recreated this myself, so there may be a typo or two. Please let me know if you have any questions!
      Pi 3 Model B
      Canakit 5v charger
      Retropie 4.4 (Update commands recently run)
      Thanks for the help!
        CDStrange
        Never mind. Checked on Reddit and got a hit for the problem I believe. Just used the PowerBlock installer in the setup menu. Seemed to work at a glance.
