    RetroAchievements Help?
    retroarch menu
    3 Posts 2 Posters 315 Views
      ratmandom
      Sorry but I could not find this info, can some one help me?
      Why does the achievements not appear on Sega mega drive/Genesis and other Sega systems. On my retropie zero?
      ... it's not on retroarch menu list and can not be unlocked ...
      Other systems are fine.
      I am on a PI ZERO is that why?
      And I have tried 2 different retropie builds.
      thelostsoulT 1 Reply Last reply Reply Quote 0
      • thelostsoulT
        thelostsoul @ratmandom
        @ratmandom Which emulator are you using? Not all support RetroAchievments I think.
        📜 RE/SET: 100 SNES Games for your RetroPie, 🎁 Share your hidden gems and insider tips
        • thelostsoulT
          thelostsoul @thelostsoul
          @thelostsoul I just looked up which emulators are supported and the most common Mega Drive emulators does. So, thats not the problem here I guess. https://docs.libretro.com/guides/retroachievements/
          I enabled RetroAchievements 2 weeks ago too on my Pi3 and not all systems did work, when they should. I can't say why. Maybe this have something to do with the RetroAchievement site itself? So, try again later. Here are the systems I tried to enable by changing the configuration files. I need to retest them too.
          Working cheevos: nes, snes, gb, gbc, gba, md, ms, gg
          Not working cheevos: ngpc, a2600, pce
          Maybe add the information from this thread first: https://retropie.org.uk/forum/topic/3/read-this-first
